Ga door naar hoofdinhoud
Sew a Straight Stitch
Wat je nodig hebt
  1. Sew a Straight Stitch, Sew a Straight Stitch: stap 1, afbeelding 1 van 2 Sew a Straight Stitch, Sew a Straight Stitch: stap 1, afbeelding 2 van 2
    • Thread your needle and tie a knot in the end of the thread.
    • We're using contrasting thread for visibility, but when you do your repair you will want to use matching thread.
    • Drive the needle through the back of the bottom material.
    • Pull the thread taut.
    Vraag FixBot
    Voeg opmerking toe
  2. Sew a Straight Stitch: stap 2, afbeelding 1 van 2 Sew a Straight Stitch: stap 2, afbeelding 2 van 2
    • Drive the needle through the back side of the top material.
    • In this case we're sewing a buckle, but you can use this stitch to sew just about anything together.
    • Align the two materials in their final position.
    Vraag FixBot
    Voeg opmerking toe
  3. Sew a Straight Stitch: stap 3, afbeelding 1 van 2 Sew a Straight Stitch: stap 3, afbeelding 2 van 2
    • Drive the needle down through both layers of material, coming out on the back side of the bottom material. Push the needle out of the material.
    • The closer you drive the needle in to where the thread came up, the smaller the stitch length. Having a smaller stitch length requires more stitches, but creates a stronger seam.
    Vraag FixBot
    Voeg opmerking toe
  4. Sew a Straight Stitch: stap 4, afbeelding 1 van 2 Sew a Straight Stitch: stap 4, afbeelding 2 van 2
    • Ensure the two layers are correctly aligned.
    • Drive the needle through both layers of fabric from the back side of the bottom material, coming up on the top side of the top material.
    Vraag FixBot
    Voeg opmerking toe
  5. Sew a Straight Stitch: stap 5, afbeelding 1 van 3 Sew a Straight Stitch: stap 5, afbeelding 2 van 3 Sew a Straight Stitch: stap 5, afbeelding 3 van 3
    • Continue sewing through both layers, going down from the top and up from the bottom, as described in steps 3 and 4 of this guide.
    • When you come to the end of your material, draw the needle in between the two layers of material, under the thread of the closest stitch.
    • Slowly start to pull the thread taut. As you pull a loop will form.
    • Draw the needle through the loop and pull the thread taut.
    • Repeat the process of drawing the needle between the layers, creating a loop, and drawing the needle through the loop as described in this step.
    Vraag FixBot
    Voeg opmerking toe
  6. Sew a Straight Stitch: stap 6, afbeelding 1 van 1
    • Cut any remaining thread and admire your work.
    Vraag FixBot
    Voeg opmerking toe
Eindstreep
5 andere personen hebben deze handleiding voltooid.
Brittany McCrigler
90.933 Reputatie
142 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 33
Afgelopen 30 dagen: 117
Altijd: 5,201
