Ga door naar hoofdinhoud
Screen Replacement
Wat je nodig hebt
  1. Screen Replacement, Back Cover: stap 1, afbeelding 1 van 3 Screen Replacement, Back Cover: stap 1, afbeelding 2 van 3 Screen Replacement, Back Cover: stap 1, afbeelding 3 van 3
    • Insert the plastic opening tool into the middle of the bottom edge of the device. The tool should be inserted within the seam between the back and front covers.
    • Slide the opening tool to the right and slowly continue to separate the back cover from the device.
    • Avoid prying on the buttons, as they are easily damaged.
    Vraag FixBot
    Voeg opmerking toe
  2. Screen Replacement: stap 2, afbeelding 1 van 1
    • Pull the cover off of the device once about three quarters of the cover has been pried open using the plastic opening tool.
    Vraag FixBot
    Voeg opmerking toe
  3. Screen Replacement, Battery: stap 3, afbeelding 1 van 1
    • Remove masking tape from the battery.
    Vraag FixBot
    Voeg opmerking toe
  4. Screen Replacement: stap 4, afbeelding 1 van 3 Screen Replacement: stap 4, afbeelding 2 van 3 Screen Replacement: stap 4, afbeelding 3 van 3
    • Pry the battery from the base using the nylon spudger and move it away from the motherboard.
    • Handle the battery with care to avoid damaging it.
    Vraag FixBot
    Voeg opmerking toe
  5. Screen Replacement: stap 5, afbeelding 1 van 3 Screen Replacement: stap 5, afbeelding 2 van 3 Screen Replacement: stap 5, afbeelding 3 van 3
    • De-solder the three contact points and remove the battery.
    • See the following guide for instructions on how to solder. Hoe moet je (de-)solderen?
    • Use caution when operating the soldering iron.
    Vraag FixBot
    Voeg opmerking toe
  6. Screen Replacement, Motherboard: stap 6, afbeelding 1 van 3 Screen Replacement, Motherboard: stap 6, afbeelding 2 van 3 Screen Replacement, Motherboard: stap 6, afbeelding 3 van 3
    • Remove the two ZIF connectors attached to the motherboard by flipping up the black tabs before pulling the ribbon cable away.
    • Only use a fingernail or nylon spudger to flip up the retaining flap. Using metal tools may damage delicate components.
    Vraag FixBot
    Voeg opmerking toe
  7. Screen Replacement: stap 7, afbeelding 1 van 1
    • Use the nut driver and J00 bit to remove the three 4 mm screws.
    Vraag FixBot
    Voeg opmerking toe
  8. Screen Replacement: stap 8, afbeelding 1 van 3 Screen Replacement: stap 8, afbeelding 2 van 3 Screen Replacement: stap 8, afbeelding 3 van 3
    • Peel back metal tape that is hiding the auxiliary port wires.
    • Remove tape that is holding the speaker wires in place.
    • Lift up on the motherboard to release it from the tablet.
    Vraag FixBot
    Voeg opmerking toe
  9. Screen Replacement, Screen: stap 9, afbeelding 1 van 1
    • Use the nut driver and the J0 bit to unscrew the four 4 mm screws
    Vraag FixBot
    Voeg opmerking toe
  10. Screen Replacement: stap 10, afbeelding 1 van 2 Screen Replacement: stap 10, afbeelding 2 van 2
    • If your are replacing a broken screen be careful when handling broken glass.
    • Remove the screen from the front cover of the device. At this point there should be no other component holding the screen down.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Walker Karstens
364 Reputatie
3 handleidingen geschreven
Baylor, Team 4-1, Williams Fall 2016 Lid van Baylor, Team 4-1, Williams Fall 2016
BU-WILLIAMS-F16S4G1
4 Leden
14 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 29
Afgelopen 30 dagen: 95
Altijd: 3,600
