Inleiding
Save yourself some money by replacing your screen door mesh with this guide. This guide assumes that you've already removed the old mesh and spline.
Wat je nodig hebt
Place the screen door on a completely flat surface. Lay the new screen across the frame.
Use tape or clamps along the bottom edge of the screen to keep it taut against the frame.
18 andere personen hebben deze handleiding voltooid.
9Gids Commentaar
really helpful; my problem is i have huge lanai windows that need to be rescreened; its very daunting because you cannot lay them down, you are working in mid air; the basic principles here will apply but how do you get started. Even just tucking the screen back in where its become loose is hard to do without it bagging out or sagging here and there. Thanx, will help when I do the door.
Start with the top side!
nicO -
Really helpful guide, thanks! I made an edit to omit the part about making sure the small squares in the mesh align with the frame because (as I experienced in my case) the mesh wasn't cut perfectly parallel, so there wasn't enough overlap if I aligned them this way. I think the most important part is to just make sure there's enough overlap on all sides.
Nice article. Thank you for sharing this. Its really helpful. Step by step instruction on door replacement is good. We expect more from your side
