Ga door naar hoofdinhoud
Samsung Watch Active Sensor Array Replacement
Wat je nodig hebt
  1. Samsung Watch Active Sensor Array Replacement, Turn off the watch: stap 1, afbeelding 1 van 2 Samsung Watch Active Sensor Array Replacement, Turn off the watch: stap 1, afbeelding 2 van 2
    • Turn off the Galaxy Watch Active by pushing and holding the bottom button for approximately 3 seconds. You should feel a short vibration.
    • When the "Power off" symbol appears tap the center of the screen to make it shut down. You should feel a longer vibration for confirmation.
    Vraag FixBot
    Voeg opmerking toe
  2. Samsung Watch Active Sensor Array Replacement, Remove the rear screws: stap 2, afbeelding 1 van 1
    • Use a Tri-point Y00 screwdriver to remove the four 4 mm-long screws on the back of the watch.
    Vraag FixBot
    Voeg opmerking toe
  3. Samsung Watch Active Sensor Array Replacement, Separate the back cover from the housing: stap 3, afbeelding 1 van 3 Samsung Watch Active Sensor Array Replacement, Separate the back cover from the housing: stap 3, afbeelding 2 van 3 Samsung Watch Active Sensor Array Replacement, Separate the back cover from the housing: stap 3, afbeelding 3 van 3
    • Use an opening tool and place it between the plastic back cover and the metal housing near the buttons.
    • Push the tip of the opening tool into the gap to separate the back cover from the housing.
    • Don’t remove the back cover all the way yet. There is a cable connecting it to the motherboard.
    Vraag FixBot
    Voeg opmerking toe
  4. Samsung Watch Active Sensor Array Replacement, Disconnect the sensor array: stap 4, afbeelding 1 van 2 Samsung Watch Active Sensor Array Replacement, Disconnect the sensor array: stap 4, afbeelding 2 van 2
    • Carefully lift the back cover approximately 2 cm to access the sensor array connector near the two buttons.
    • Use a spudger to disconnect the sensor array from the motherboard.
    Vraag FixBot
    Voeg opmerking toe
  5. Samsung Watch Active Sensor Array Replacement, Remove the back cover: stap 5, afbeelding 1 van 1
    • Remove the back cover.
    Vraag FixBot
    Voeg opmerking toe
  6. Samsung Watch Active Sensor Array Replacement, Loosen the sensor array: stap 6, afbeelding 1 van 3 Samsung Watch Active Sensor Array Replacement, Loosen the sensor array: stap 6, afbeelding 2 van 3 Samsung Watch Active Sensor Array Replacement, Loosen the sensor array: stap 6, afbeelding 3 van 3
    • Use an opening pick and slide it underneath the sensor array which is slightly glued in place.
    • Carefully twist the opening pick to separate the sensor array from the back cover.
    Vraag FixBot
    Voeg opmerking toe
  7. Samsung Watch Active Sensor Array Replacement, Remove the sensor array: stap 7, afbeelding 1 van 2 Samsung Watch Active Sensor Array Replacement, Remove the sensor array: stap 7, afbeelding 2 van 2
    • Remove the sensor array from the back cover.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Tobias Isakeit
133.935 Reputatie
189 handleidingen geschreven
Tobias Isakeit - Repairability Engineer Lid van Tobias Isakeit - Repairability Engineer
Business
1 Lid
1.151 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 12
Afgelopen 30 dagen: 49
Altijd: 4,851
