Ga door naar hoofdinhoud
Samsung WB1100F Motherboard Replacement
Wat je nodig hebt
    1. Samsung WB1100F Motherboard Replacement, LCD Screen Cover: stap 1, afbeelding 1 van 2 Samsung WB1100F Motherboard Replacement, LCD Screen Cover: stap 1, afbeelding 2 van 2
      • Remove six 1.2 mm Phillips #00 screws connected to the tripod dock and adjacent screws.
      • Remove six 1.2 mm Phillips #00 screws from the side of the camera.
      Vraag FixBot
      Voeg opmerking toe
    2. Samsung WB1100F Motherboard Replacement: stap 2, afbeelding 1 van 2 Samsung WB1100F Motherboard Replacement: stap 2, afbeelding 2 van 2
      • Use a plastic opening tool or spudger if available.
      • Using the flat end of a spudger, loosen the connection between the back panel and the device. Remove the back panel using your hands.
      Vraag FixBot
      Voeg opmerking toe
    1. Samsung WB1100F Motherboard Replacement, LCD Screen: stap 3, afbeelding 1 van 2 Samsung WB1100F Motherboard Replacement, LCD Screen: stap 3, afbeelding 2 van 2
      • Remove four 1.2 mm Phillips #1 screws connected to the LCD screen.
      Vraag FixBot
      Voeg opmerking toe
    2. Samsung WB1100F Motherboard Replacement: stap 4, afbeelding 1 van 3 Samsung WB1100F Motherboard Replacement: stap 4, afbeelding 2 van 3 Samsung WB1100F Motherboard Replacement: stap 4, afbeelding 3 van 3
      Gereedschap gebruikt in deze stap:
      • Flip the LCD screen over to reveal the display cable.
      • Use the tip of a spudger or your fingernail to flip up the small retaining flap on the display cable ZIF connector.
      • Be sure you are prying up on the hinged retaining flap, not the connector itself.
      • Using a pair of tweezers, remove the ribbon cable from its socket on the motherboard.
      • The white line on this ribbon cable marks the edge of the connection area. To reinstall, insert the cable into the connector up to this line, and then close the retaining flap. If the cable doesn’t insert easily up to (or very near to) this line, it’s probably misaligned and needs to be gently removed and repositioned.
      Vraag FixBot
      Voeg opmerking toe
    1. Samsung WB1100F Motherboard Replacement, Motherboard: stap 5, afbeelding 1 van 1
      • Remove two 1.2 Phillips #00 screws connected to the motherboard.
      Vraag FixBot
      Voeg opmerking toe
    2. Samsung WB1100F Motherboard Replacement: stap 6, afbeelding 1 van 1
      • Desolder five wires connected to the camera motherboard.
      Vraag FixBot
      Voeg opmerking toe
    3. Samsung WB1100F Motherboard Replacement: stap 7, afbeelding 1 van 2 Samsung WB1100F Motherboard Replacement: stap 7, afbeelding 2 van 2
      • Use the tip of a spudger or your fingernail to flip up the small retaining flaps on the five ZIF connectors on the motherboard.
      • Detach the five ribbon cables from the camera motherboard.
      • The white line on the ribbon cables mark the edge of the connection area. To reinstall, insert the cables into the connector up to this line, and then close the retaining flap. If a cable doesn’t insert easily up to (or very near to) this line, it’s probably misaligned and needs to be gently removed and repositioned.
      Vraag FixBot
      Voeg opmerking toe
    4. Samsung WB1100F Motherboard Replacement: stap 8, afbeelding 1 van 1
      • Gently remove the motherboard.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Jesse Lindsey
581 Reputatie
5 handleidingen geschreven
Metro State, Team 1-1, Carpenter SU 2016 Lid van Metro State, Team 1-1, Carpenter SU 2016
MSU-CARPENTER-SU16S1G1
3 Leden
1Gids Commentaar
Great Jesse, I can say the same applies for the WB100, I get one and I already disassembly it to fix humidity condensation in the top buttons, unfortunately the flash stops working..
Congratulation for your post. Enrique
egyr - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 11
Afgelopen 30 dagen: 44
Altijd: 1,649
