Ga door naar hoofdinhoud
Samsung WB1100F Camera Lens Replacement
Wat je nodig hebt
    1. Samsung WB1100F Camera Lens Replacement, LCD Screen Cover: stap 1, afbeelding 1 van 2 Samsung WB1100F Camera Lens Replacement, LCD Screen Cover: stap 1, afbeelding 2 van 2
      • Remove six 1.2 mm Phillips #00 screws connected to the tripod dock and adjacent screws.
      • Remove six 1.2 mm Phillips #00 screws from the side of the camera.
      Vraag FixBot
      Voeg opmerking toe
    2. Samsung WB1100F Camera Lens Replacement: stap 2, afbeelding 1 van 2 Samsung WB1100F Camera Lens Replacement: stap 2, afbeelding 2 van 2
      • Use a plastic opening tool or spudger if available.
      • Using the flat end of a spudger, loosen the connection between the back panel and the device. Remove the back panel using your hands.
      Vraag FixBot
      Voeg opmerking toe
    1. Samsung WB1100F Camera Lens Replacement, LCD Screen: stap 3, afbeelding 1 van 2 Samsung WB1100F Camera Lens Replacement, LCD Screen: stap 3, afbeelding 2 van 2
      • Remove four 1.2 mm Phillips #1 screws connected to the LCD screen.
      Vraag FixBot
      Voeg opmerking toe
    2. Samsung WB1100F Camera Lens Replacement: stap 4, afbeelding 1 van 3 Samsung WB1100F Camera Lens Replacement: stap 4, afbeelding 2 van 3 Samsung WB1100F Camera Lens Replacement: stap 4, afbeelding 3 van 3
      Gereedschap gebruikt in deze stap:
      • Flip the LCD screen over to reveal the display cable.
      • Use the tip of a spudger or your fingernail to flip up the small retaining flap on the display cable ZIF connector.
      • Be sure you are prying up on the hinged retaining flap, not the connector itself.
      • Using a pair of tweezers, remove the ribbon cable from its socket on the motherboard.
      • The white line on this ribbon cable marks the edge of the connection area. To reinstall, insert the cable into the connector up to this line, and then close the retaining flap. If the cable doesn’t insert easily up to (or very near to) this line, it’s probably misaligned and needs to be gently removed and repositioned.
      Vraag FixBot
      Voeg opmerking toe
    1. Samsung WB1100F Camera Lens Replacement, Motherboard: stap 5, afbeelding 1 van 1
      • Remove two 1.2 Phillips #00 screws connected to the motherboard.
      Vraag FixBot
      Voeg opmerking toe
    2. Samsung WB1100F Camera Lens Replacement: stap 6, afbeelding 1 van 1
      • Desolder five wires connected to the camera motherboard.
      Vraag FixBot
      Voeg opmerking toe
    3. Samsung WB1100F Camera Lens Replacement: stap 7, afbeelding 1 van 2 Samsung WB1100F Camera Lens Replacement: stap 7, afbeelding 2 van 2
      • Use the tip of a spudger or your fingernail to flip up the small retaining flaps on the five ZIF connectors on the motherboard.
      • Detach the five ribbon cables from the camera motherboard.
      • The white line on the ribbon cables mark the edge of the connection area. To reinstall, insert the cables into the connector up to this line, and then close the retaining flap. If a cable doesn’t insert easily up to (or very near to) this line, it’s probably misaligned and needs to be gently removed and repositioned.
      Vraag FixBot
      Voeg opmerking toe
    4. Samsung WB1100F Camera Lens Replacement: stap 8, afbeelding 1 van 1
      • Gently remove the motherboard.
      Vraag FixBot
      Voeg opmerking toe
    1. Samsung WB1100F Camera Lens Replacement, Camera Lens: stap 9, afbeelding 1 van 1
      • Remove the three 1.5 mm Phillips #1 screws connected to the lens assembly.
      Vraag FixBot
      Voeg opmerking toe
    2. Samsung WB1100F Camera Lens Replacement: stap 10, afbeelding 1 van 2 Samsung WB1100F Camera Lens Replacement: stap 10, afbeelding 2 van 2
      • Pull the lens assembly from main body of the camera, using a spudger to pry if necessary.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Jesse Lindsey
581 Reputatie
5 handleidingen geschreven
Metro State, Team 1-1, Carpenter SU 2016 Lid van Metro State, Team 1-1, Carpenter SU 2016
MSU-CARPENTER-SU16S1G1
3 Leden
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 16
Afgelopen 30 dagen: 50
Altijd: 3,658
