Ga door naar hoofdinhoud
Samsung SmartThings Hub Power Port Replacement
Wat je nodig hebt
  1. Samsung SmartThings Hub Power Port  Replacement, Power Port: stap 1, afbeelding 1 van 1
    • To open your device, gently slide the grey bottom cover in the direction of the arrow as shown.
    Vraag FixBot
    Voeg opmerking toe
  2. Samsung SmartThings Hub Power Port  Replacement: stap 2, afbeelding 1 van 3 Samsung SmartThings Hub Power Port  Replacement: stap 2, afbeelding 2 van 3 Samsung SmartThings Hub Power Port  Replacement: stap 2, afbeelding 3 van 3
    • Make sure the batteries are removed before attempting disassembly.
    • Using your Phillips #1 screwdriver, remove the four visible 12.5mm screws.
    • Next, either peel up the longer of the two stickers or punch a hole with the tip of your screwdriver to access the fifth 12.5mm screw.
    Vraag FixBot
    Voeg opmerking toe
  3. Samsung SmartThings Hub Power Port  Replacement: stap 3, afbeelding 1 van 3 Samsung SmartThings Hub Power Port  Replacement: stap 3, afbeelding 2 van 3 Samsung SmartThings Hub Power Port  Replacement: stap 3, afbeelding 3 van 3
    • Once all five screws are removed, split the casing apart by applying gentle upwards pressure against the positive terminals in the battery compartment.
    Vraag FixBot
    Voeg opmerking toe
  4. Samsung SmartThings Hub Power Port  Replacement: stap 4, afbeelding 1 van 2 Samsung SmartThings Hub Power Port  Replacement: stap 4, afbeelding 2 van 2
    • To remove the motherboard, grip the USB port and the Ethernet port. Lift up, then slide towards the front of the device to release the motherboard from the black retaining clip shown on the right.
    Vraag FixBot
    Voeg opmerking toe
  5. Samsung SmartThings Hub Power Port  Replacement: stap 5, afbeelding 1 van 3 Samsung SmartThings Hub Power Port  Replacement: stap 5, afbeelding 2 van 3 Samsung SmartThings Hub Power Port  Replacement: stap 5, afbeelding 3 van 3
    • Place the motherboard on a clean, flat surface.
    • Preheat your soldering iron. The power port has three points of connection to the motherboard (pictured below). Using your soldering iron, apply heat to each solder joint in turn while pulling the power port away from the board.
    • Soldering irons can reach temperatures of over 500 degrees. Watch your fingers!
    • For more information on soldering refer to How to Solder and Desolder Connections
    Vraag FixBot
    Voeg opmerking toe
  6. Samsung SmartThings Hub Power Port  Replacement: stap 6, afbeelding 1 van 2 Samsung SmartThings Hub Power Port  Replacement: stap 6, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    • Using tweezers, remove the desoldered power port from the motherboard.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
5 andere personen hebben deze handleiding voltooid.
Erin
494 Reputatie
4 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 26
Altijd: 1,597
