Ga door naar hoofdinhoud
Samsung SmartThings Hub Ethernet Port Replacement
Wat je nodig hebt
    1. Samsung SmartThings Hub Ethernet Port  Replacement, Ethernet Port: stap 1, afbeelding 1 van 1
      • To open your device, gently slide the grey bottom cover in the direction of the arrow as shown.
      Vraag FixBot
      Voeg opmerking toe
    2. Samsung SmartThings Hub Ethernet Port  Replacement: stap 2, afbeelding 1 van 3 Samsung SmartThings Hub Ethernet Port  Replacement: stap 2, afbeelding 2 van 3 Samsung SmartThings Hub Ethernet Port  Replacement: stap 2, afbeelding 3 van 3
      • Make sure the batteries are removed before attempting disassembly.
      • Using your Phillips #1 screwdriver, remove the four visible 12.5mm screws.
      • Next, either peel up the longer of the two stickers or punch a hole with the tip of your screwdriver to access the fifth 12.5mm screw.
      Vraag FixBot
      Voeg opmerking toe
    3. Samsung SmartThings Hub Ethernet Port  Replacement: stap 3, afbeelding 1 van 3 Samsung SmartThings Hub Ethernet Port  Replacement: stap 3, afbeelding 2 van 3 Samsung SmartThings Hub Ethernet Port  Replacement: stap 3, afbeelding 3 van 3
      • Once all five screws are removed, split the casing apart by applying gentle upwards pressure against the positive terminals in the battery compartment.
      Vraag FixBot
      Voeg opmerking toe
    4. Samsung SmartThings Hub Ethernet Port  Replacement: stap 4, afbeelding 1 van 2 Samsung SmartThings Hub Ethernet Port  Replacement: stap 4, afbeelding 2 van 2
      • To remove the motherboard, grip the USB port and the Ethernet port. Lift up, then slide towards the front of the device to release the motherboard from the black retaining clip shown on the right.
      Vraag FixBot
      Voeg opmerking toe
    5. Samsung SmartThings Hub Ethernet Port  Replacement: stap 5, afbeelding 1 van 2 Samsung SmartThings Hub Ethernet Port  Replacement: stap 5, afbeelding 2 van 2
      • Place the motherboard on a clean, flat surface.
      • Preheat your soldering iron. The Ethernet port has fourteen points of connection to the motherboard (pictured below). Using your soldering iron, apply heat to each solder joint in turn while pulling the Ethernet port away from the board.
      • Soldering irons can reach temperatures of over 500 degrees. Watch your fingers!
      • For more information on soldering refer to How to Solder and Desolder Connections
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Erin
494 Reputatie
4 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 16
Altijd: 1,213
