Ga door naar hoofdinhoud
Samsung Impression Antenna Replacement
Wat je nodig hebt
  1. Samsung Impression Antenna Replacement, Battery: stap 1, afbeelding 1 van 1
    • Orient the phone with the screen facing downward.
    • Slide the panel away from the camera using your thumb. This will expose the battery.
    Vraag FixBot
    Voeg opmerking toe
  2. Samsung Impression Antenna Replacement: stap 2, afbeelding 1 van 2 Samsung Impression Antenna Replacement: stap 2, afbeelding 2 van 2
    • Insert the tip of the spudger on the left side of the battery.
    • Pry the battery out. It will pivot in the direction of the white arrow.
    Vraag FixBot
    Voeg opmerking toe
  3. Samsung Impression Antenna Replacement, Back Cover: stap 3, afbeelding 1 van 1
    • Remove the six 3.5 mm screws using a Phillips #000 screwdriver. Unscrew in a counterclockwise direction.
    Vraag FixBot
    Voeg opmerking toe
  4. Samsung Impression Antenna Replacement: stap 4, afbeelding 1 van 1
    • Gently pry around the edges with the spudger to remove back panel.
    • It may help to slide the touchscreen upwards when removing the back panel.
    • The side buttons will become loose and will fall out, so put these in a safe place.
    Vraag FixBot
    Voeg opmerking toe
  5. Samsung Impression Antenna Replacement, Circuit Board: stap 5, afbeelding 1 van 1
    • Gently remove the black wire to free the circuit board.
    • Remove the wire by gently prying up the gold terminator attached to the green circuit board.
    Vraag FixBot
    Voeg opmerking toe
  6. Samsung Impression Antenna Replacement: stap 6, afbeelding 1 van 2 Samsung Impression Antenna Replacement: stap 6, afbeelding 2 van 2
    • Gently tug the black and blue ribbon upwards to release the circuit board.
    Vraag FixBot
    Voeg opmerking toe
  7. Samsung Impression Antenna Replacement, Antenna: stap 7, afbeelding 1 van 2 Samsung Impression Antenna Replacement, Antenna: stap 7, afbeelding 2 van 2
    • Use a Phillips screwdriver to remove the six 3.5 mm screws by rotating.
    • The antenna assembly will snap off.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
To replace the antenna and reassemble your device, follow the steps in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Één andere persoon heeft deze handleiding voltooid.
Saul Villatoro
260 Reputatie
7 handleidingen geschreven
Cal Poly, Team 8-10, Regan Spring 2011 Lid van Cal Poly, Team 8-10, Regan Spring 2011
CPSU-REGAN-S11S8G10
4 Leden
45 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 32
Altijd: 3,298
