Ga door naar hoofdinhoud
Samsung Glyde LCD Screen Replacement
Wat je nodig hebt
  1. Samsung Glyde LCD Screen Replacement, Battery: stap 1, afbeelding 1 van 1
    • Using your thumb, press down and slide the back cover away from the camera.
    Vraag FixBot
    Voeg opmerking toe
  2. Samsung Glyde LCD Screen Replacement: stap 2, afbeelding 1 van 1
    • Remove the battery from the phone by using your plastic opening tool to find a gap at any edge of the battery and lifting the battery up.
    Vraag FixBot
    Voeg opmerking toe
  3. Samsung Glyde LCD Screen Replacement, Keyboard: stap 3, afbeelding 1 van 2 Samsung Glyde LCD Screen Replacement, Keyboard: stap 3, afbeelding 2 van 2
    • Use a Phillips #00 screwdriver to remove the six 4mm screws.
    Vraag FixBot
    Voeg opmerking toe
  4. Samsung Glyde LCD Screen Replacement: stap 4, afbeelding 1 van 2 Samsung Glyde LCD Screen Replacement: stap 4, afbeelding 2 van 2
    • Find a gap on the top side of the phone and pry apart the phone case using the plastic opening tool . Use moderate pressure to slowly maneuver around until the case is pryed apart.
    • Take the case off with your fingers
    Vraag FixBot
    Voeg opmerking toe
  5. Samsung Glyde LCD Screen Replacement: stap 5, afbeelding 1 van 2 Samsung Glyde LCD Screen Replacement: stap 5, afbeelding 2 van 2
    • The green film is located above the camera. It is the camera connector to the motherboard.
    • Disconnect the camera connector with the plastic opening tool.
    Vraag FixBot
    Voeg opmerking toe
  6. Samsung Glyde LCD Screen Replacement: stap 6, afbeelding 1 van 2 Samsung Glyde LCD Screen Replacement: stap 6, afbeelding 2 van 2
    • Take a close up of the picture for this step for a better view.
    • Use a plastic opening tool to disconnect the keyboard connector.
    Vraag FixBot
    Voeg opmerking toe
  7. Samsung Glyde LCD Screen Replacement: stap 7, afbeelding 1 van 2 Samsung Glyde LCD Screen Replacement: stap 7, afbeelding 2 van 2
    • The motherboard is held in place by the circular connector.
    • Using a plastic opening tool, disconnect the circular connector.
    Vraag FixBot
    Voeg opmerking toe
  8. Samsung Glyde LCD Screen Replacement: stap 8, afbeelding 1 van 3 Samsung Glyde LCD Screen Replacement: stap 8, afbeelding 2 van 3 Samsung Glyde LCD Screen Replacement: stap 8, afbeelding 3 van 3
    • A LCD connector is located underneath the motherboard.
    • Lift the far edge of the motherboard gently upwards toward the center.
    • Using a plastic opening tool, disconnect the LCD connector.
    Vraag FixBot
    Voeg opmerking toe
  9. Samsung Glyde LCD Screen Replacement: stap 9, afbeelding 1 van 2 Samsung Glyde LCD Screen Replacement: stap 9, afbeelding 2 van 2
    • Lift the motherboard up with your fingers.
    • Place the motherboard in a secure area.
    Vraag FixBot
    Voeg opmerking toe
  10. Samsung Glyde LCD Screen Replacement: stap 10, afbeelding 1 van 3 Samsung Glyde LCD Screen Replacement: stap 10, afbeelding 2 van 3 Samsung Glyde LCD Screen Replacement: stap 10, afbeelding 3 van 3
    • Look for the antenna which is located at the bottom end of the device. Prop the antenna out by using the plastic opening tool and slipping the tip of the tool into the edges of the antenna.
    • Using the plastic opening tool, disconnect the connector that leads from the phone to the antenna.
    • With your hands finish prying apart the antenna by lifting it up.
    Vraag FixBot
    Voeg opmerking toe
  11. Samsung Glyde LCD Screen Replacement: stap 11, afbeelding 1 van 2 Samsung Glyde LCD Screen Replacement: stap 11, afbeelding 2 van 2
    • The keyboard chip is located on top of the device. Pry the keyboard off of the case with the plastic opening tool.
    Vraag FixBot
    Voeg opmerking toe
  12. Samsung Glyde LCD Screen Replacement, LCD Screen: stap 12, afbeelding 1 van 2 Samsung Glyde LCD Screen Replacement, LCD Screen: stap 12, afbeelding 2 van 2
    • Using a #00 screwdriver, remove the 8 2mm screws connecting the display case to the sliding mechanism.
    Vraag FixBot
    Voeg opmerking toe
  13. Samsung Glyde LCD Screen Replacement: stap 13, afbeelding 1 van 2 Samsung Glyde LCD Screen Replacement: stap 13, afbeelding 2 van 2
    • Now remove the 5 4mm screws located under the sliding mechanism connecting the back-plate to the display.
    • You will need to maneuver the sliding mechanism around to reach all of the screws.
    Vraag FixBot
    Voeg opmerking toe
  14. Samsung Glyde LCD Screen Replacement: stap 14, afbeelding 1 van 3 Samsung Glyde LCD Screen Replacement: stap 14, afbeelding 2 van 3 Samsung Glyde LCD Screen Replacement: stap 14, afbeelding 3 van 3
    • Now it's time to desolder some components. You can gain some instruction from here.
    • Using your soldering wick and a soldering iron, desolder the contacts of the flex cable.
    Vraag FixBot
    Voeg opmerking toe
  15. Samsung Glyde LCD Screen Replacement: stap 15, afbeelding 1 van 1
    • After desoldering, verify that the gates on the two flex cables are in the "up" position and remove them.
    Vraag FixBot
    Voeg opmerking toe
  16. Samsung Glyde LCD Screen Replacement: stap 16, afbeelding 1 van 3 Samsung Glyde LCD Screen Replacement: stap 16, afbeelding 2 van 3 Samsung Glyde LCD Screen Replacement: stap 16, afbeelding 3 van 3
    • Using gentle fingers, pry the LCD screen out of its housing.
    • The flex cables connecting everything to the LCD screen are very sensitive to touch, and don't react well to pulling/tearing motions.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Cameron Law
142 Reputatie
5 handleidingen geschreven
Cal Poly, Team 3-12, Regan Fall 2011 Lid van Cal Poly, Team 3-12, Regan Fall 2011
CPSU-REGAN-F11S3G12
4 Leden
28 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 34
Altijd: 2,639
