Ga door naar hoofdinhoud
Samsung Galaxy Tab 2 10.1 Charger Port Replacement
Wat je nodig hebt
  1. Samsung Galaxy Tab 2 10.1 Charger Port Replacement, Back Cover: stap 1, afbeelding 1 van 2 Samsung Galaxy Tab 2 10.1 Charger Port Replacement, Back Cover: stap 1, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    Heavy-Duty Spudger
    • The plastic opening tool may break during this step. You may need to use the heavy duty spudger instead.
    • Insert the plastic opening tool between the glass screen and the back cover so the curved end of the plastic opening tool is under the glass. Gently pry the back cover away from the glass screen.
    • Be sure to lift the entire display from the body and that you are not are lifting the glass from the display. You will need to reach down a little further for the correct removal.
    • Continue inserting the plastic opening tool around the whole device screen to completely separate the back cover from the glass screen.
    Note that the headphone port protrudes into the back cover framing. Hence the rest of the back needs to be unclipped and taken off first.
    Levi Howard - Antwoord
    I had problems getting it to separate at first. Pushing down with my thumb on the very edge of the case from the front while pushing up with my fingers from the back flexed it enough to get a very small jeweler’s screwdriver in the gap. From there I worked it until I could get the little bread wrapper plastics clips in the space. When it needed something stronger a 1 or 2 inch plastic putty knife from Walmart did the trick.
    William H Bowers - Antwoord
    I replaced the battery and nothing no screen nothing. the batt was 3.7 V though.
    The old one had 0V. I might have messed up the ribbon cables?
    I put back the cover on it.
    Held on the power button for 10 seconds, nothing. Held the power button and the volume up button for 10 seconds… also nothing..
    I am leaving it charge for a while now. Even though if your battery is like full (3.7V measured) it should come on… but nothing..
    Lets wait and see. Or this will be garbage…
    xbox40489 - Antwoord
  2. Samsung Galaxy Tab 2 10.1 Charger Port Replacement: stap 2, afbeelding 1 van 2 Samsung Galaxy Tab 2 10.1 Charger Port Replacement: stap 2, afbeelding 2 van 2
    • Gently lift the screen up with your finger.
    • If the screen will not separate from the back cover, try repeating step 1.
  3. Samsung Galaxy Tab 2 10.1 Charger Port Replacement, Battery Disconnect: stap 3, afbeelding 1 van 1
    • Using your fingers, remove the green tape covering the battery connector.
  4. Samsung Galaxy Tab 2 10.1 Charger Port Replacement: stap 4, afbeelding 1 van 3 Samsung Galaxy Tab 2 10.1 Charger Port Replacement: stap 4, afbeelding 2 van 3 Samsung Galaxy Tab 2 10.1 Charger Port Replacement: stap 4, afbeelding 3 van 3
    Heavy-Duty Spudger
    • Insert the flat end of the heavy-duty spudger between the wires and underneath the battery connector. Carefully lift the black battery connector up to disconnect it from the motherboard.
    • The metal spudger shown in the photo is not recommended due to the possibility of an electrical short. Use an ESD-safe tool, such as a heavy-duty (nylon) spudger.
  5. Samsung Galaxy Tab 2 10.1 Charger Port Replacement, Charger Port: stap 5, afbeelding 1 van 2 Samsung Galaxy Tab 2 10.1 Charger Port Replacement, Charger Port: stap 5, afbeelding 2 van 2
    • The charging port cable is the black cable connected to the charger port. Using your fingers, peel the green tape off of the charging port cable connector.
  6. Samsung Galaxy Tab 2 10.1 Charger Port Replacement: stap 6, afbeelding 1 van 2 Samsung Galaxy Tab 2 10.1 Charger Port Replacement: stap 6, afbeelding 2 van 2
    Heavy-Duty Spudger
    • Using the flat end of heavy-duty spudger, carefully lift the black tab that holds the charger port cable in place.
    • Slide the cable out.
    • There is a small strip of adhesive holding the charger port cable to the battery. You may need to slide the heavy-duty spudger between the cable and the battery to slide the cable out.
  7. Samsung Galaxy Tab 2 10.1 Charger Port Replacement: stap 7, afbeelding 1 van 3 Samsung Galaxy Tab 2 10.1 Charger Port Replacement: stap 7, afbeelding 2 van 3 Samsung Galaxy Tab 2 10.1 Charger Port Replacement: stap 7, afbeelding 3 van 3
    • Use the Phillips 000 screwdriver to unscrew the two 3mm screws holding the charger port in place.
  8. Samsung Galaxy Tab 2 10.1 Charger Port Replacement: stap 8, afbeelding 1 van 1
    • Use the flat end of the heavy-duty spudger to lift the white microphone piece until it is removed from its socket.
  9. Samsung Galaxy Tab 2 10.1 Charger Port Replacement: stap 9, afbeelding 1 van 3 Samsung Galaxy Tab 2 10.1 Charger Port Replacement: stap 9, afbeelding 2 van 3 Samsung Galaxy Tab 2 10.1 Charger Port Replacement: stap 9, afbeelding 3 van 3
    • Be sure to insert the spudger underneath the charger port and not inside the charger port to avoid damaging the component
    • Slide the flat end of the heavy-duty spudger under the charger port.
    • Make sure the spudger is all the way to the back of the cavity and slide horizontally across the bottom to break the adhesive.
    Where can I buy that part from
    Ronald Thomad - Antwoord
    I need the charging port
  10. Samsung Galaxy Tab 2 10.1 Charger Port Replacement: stap 10, afbeelding 1 van 1
    • Lift the charger port with the flat end of the heavy-duty spudger and remove it from the device.
Conclusie
22 andere personen hebben deze handleiding voltooid.
John
416 Reputatie
1 Handleiding geschreven
Cal Poly, Team 6-26, Amido Winter 2015 Lid van Cal Poly, Team 6-26, Amido Winter 2015
CPSU-AMIDO-W15S6G26
5 Leden
14 handleidingen geschreven
7 opmerkingen
Dear John,
Why must one disconnet the battery in step 3 and 4, whilst that does not seem necessary to replace the cable & port for the charger only (steps 5-10), and NOT the battery....?
Regards, Frank
Frank du Mee - Antwoord
Always disconnect battery and press power button a few times to rid of any power left on device while doing repairs. especially if you are using metal tools.
Oscar C - Antwoord
My Tab 2 10.1 does not come apart this way. If you try it this way, it will damage the touch screen connector. Plus the cable is different. This looks more like a Tab 1.
K Meeker - Antwoord
Does the P5100 have the same charging port as the P7500?
julia yapkew - Antwoord
I always open the tablet and order the cable by part and rev number. you may order a part for a tablet and will most like be sent for a diff version.
Oscar C -
I'm having trouble after I tried replacing the charging port.
Everything for in and snapped in great except where the ribbon runs and conneconnects to the mother board. I believe i broke this plastic part, which seemed to allow the copper from the ribbon to connect with the MB.
Does anyone know where to get a replacement and what's the name of this piece? Thank you
David Thorne - Antwoord
If you are refering to step 6, the fpc connector will need to be soldered to the motherboard.
Oscar C -
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 21
Afgelopen 30 dagen: 91
Altijd: 39,827
