Ga door naar hoofdinhoud
Samsung Galaxy S4 Active Motherboard Replacement
Wat je nodig hebt
  1. Samsung Galaxy S4 Active Motherboard Replacement, Rear Case: stap 1, afbeelding 1 van 2 Samsung Galaxy S4 Active Motherboard Replacement, Rear Case: stap 1, afbeelding 2 van 2
    • Pry with a plastic opening tool, or your fingernail, in the divot to the left of the rear-facing camera, near the power button.
    • Lift the rear case by the corner nearest the divot and remove it from the phone.
  2. Samsung Galaxy S4 Active Motherboard Replacement, MicroSD Card: stap 2, afbeelding 1 van 1
    • Use a plastic opening tool, or your fingernail, to press the microSD card slightly deeper into its slot until you hear a click.
    • After the click, release the card and it will pop out of its slot.
    • Remove the microSD card.
  3. Samsung Galaxy S4 Active Motherboard Replacement, Battery: stap 3, afbeelding 1 van 1
    • Insert a plastic opening tool, or your finger, into the notch of the battery compartment and lift the battery upward to remove it.
  4. Samsung Galaxy S4 Active Motherboard Replacement, SIM Card: stap 4, afbeelding 1 van 1
    • Use a plastic opening tool, or your fingernail, to press the SIM card slightly deeper into its slot until you hear a click.
    • Remove the SIM card.
  5. Samsung Galaxy S4 Active Motherboard Replacement, Midframe: stap 5, afbeelding 1 van 1
    • Use the tip of a spudger to remove the four metallic pads located in each corner of the device.
    • Using a Phillips #00 screwdriver, remove the 12 screws connecting the midframe to the device.
    Important! 4 of the screws are under the little "metallic" bolsters, one at each corner. These can be removed with a plastic opening tool.
    jeremiahmitchell87 - Antwoord
  6. Samsung Galaxy S4 Active Motherboard Replacement: stap 6, afbeelding 1 van 1
    • Use the plastic opening tool to pry around the entire edge of the midframe now to release it from the front case.
  7. Samsung Galaxy S4 Active Motherboard Replacement, Motherboard: stap 7, afbeelding 1 van 3 Samsung Galaxy S4 Active Motherboard Replacement, Motherboard: stap 7, afbeelding 2 van 3 Samsung Galaxy S4 Active Motherboard Replacement, Motherboard: stap 7, afbeelding 3 van 3
    • Use the flat end of a plastic opening tool to disconnect the USB board connector.
    • Disconnect the front-facing camera cable connector.
    • Disconnect the earpiece speaker assembly cable connector.
    • Disconnect the headphone jack assembly cable connector.
    • Disconnect the display/digitizer cable connector.
    • Disconnect the antenna cable connector.
  8. Samsung Galaxy S4 Active Motherboard Replacement: stap 8, afbeelding 1 van 1
    • Remove the single 2.4 mm Phillips #00 screw from the motherboard assembly.
  9. Samsung Galaxy S4 Active Motherboard Replacement: stap 9, afbeelding 1 van 1
    • Remove the motherboard.
Conclusie
22 andere personen hebben deze handleiding voltooid.
Geoff Wacker
89.953 Reputatie
89 handleidingen geschreven
4 opmerkingen
I need a diagnosis. My device seems to be in a boot loop....any thought and suggestions would be helpful.
Justin Lujan - Antwoord
Nota1000 fera + parabéns
ricflavianoop - Antwoord
After the replacement of the motherboard, is there a procedure to Programm the old IMEI or will it imply a new IMEI?
Markus Elgrande - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 4
Altijd: 9,304
