Inleiding
Use this guide to replace the rear facing camera on your Samsung Galaxy Light.
Onderdelen
Geen onderdelen nodig.
  1. Before removing the back cover, make sure the Samsung Galaxy Light is switched off.
    • Before removing the back cover, make sure the Samsung Galaxy Light is switched off.
    • Using a plastic opening tool (or your fingernails), pry up the back cover of the device.
    • Remove the back cover.
  2. Remove the battery from the device.
    • Remove the battery from the device.
    • Using a Phillips #0 screwdriver, remove all nine (9) screws attaching the midframe to the front of the device.
    • Using the plastic opening tool, separate the midframe from the front panel of the device.
    • Remove the midframe.
    • To detach the motherboard from the device:
      • Using the plastic opening tool, carefully pry up the digitizer connector from the motherboard.
      • Carefully lift the motherboard up and move it toward the left side of the device.
      • Using the plastic opening tool, carefully pry up the display connector on the back side of the motherboard.
    • Use a plastic opening tool to disconnect the rear facing camera from the motherboard.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Geoff Wacker
73.628 Reputatie
84 handleidingen geschreven
Weergavestatistieken:
Afgelopen 24 Uren: 0
Afgelopen 7 Dagen: 0
Afgelopen 30 Dagen: 0
Altijd: 367
