Ga door naar hoofdinhoud
Samsung Droid Charge SIM Card Port Replacement
Wat je nodig hebt
  1. Samsung Droid Charge SIM Card Port Replacement, Rear Cover: stap 1, afbeelding 1 van 1
    • Open up the back case on the phone from the groove in the bottom of the phone.
    • You can do this by inserting a fingernail or similarly thin object into the groove and pulling up with mild force.
    Vraag FixBot
    Voeg opmerking toe
  2. Samsung Droid Charge SIM Card Port Replacement, Battery: stap 2, afbeelding 1 van 1
    • Below the left part of the bottom of the battery area there will be a groove large enough to fit in a finger or screw driver head.
    • Use the groove to lever out the battery gently, in order to not damage either the battery or phone. Store the battery in a safe place.
    Vraag FixBot
    Voeg opmerking toe
  3. Samsung Droid Charge SIM Card Port Replacement, microSD: stap 3, afbeelding 1 van 1
    • Push the SD card further into its metal slot until you hear a click.
    • Release the card, and it should automatically eject itself.
    • Remove the SD card.
    Vraag FixBot
    Voeg opmerking toe
  4. Samsung Droid Charge SIM Card Port Replacement, SIM Card: stap 4, afbeelding 1 van 1
    • Slide the SIM card out of its casing by pushing on it and sliding it upward.
    Vraag FixBot
    Voeg opmerking toe
  5. Samsung Droid Charge SIM Card Port Replacement, SIM Card Port: stap 5, afbeelding 1 van 1
    • Carefully remove the back cover.
    • Remove the two 5mm screws with a small Phillips head screwdriver.
    Vraag FixBot
    Voeg opmerking toe
  6. Samsung Droid Charge SIM Card Port Replacement: stap 6, afbeelding 1 van 1
    • Removal of the back half of the casing.
    • Using a thin plastic flat head screw driver, or similar item. On the side of the phone insert the thin edge into the visible split between the 2 halves of the phone.
    • Use a prying motion to lift the casing up. This will separate the phone casing.
    • Repeat this motion all around the screen edge until the casing pops off.
    Vraag FixBot
    Voeg opmerking toe
  7. Samsung Droid Charge SIM Card Port Replacement: stap 7, afbeelding 1 van 1
    • Release the volume button flex cable on the right.
    • Release the pop connector on the motherboard located to the left of the SIM card port.
    Vraag FixBot
    Voeg opmerking toe
  8. Samsung Droid Charge SIM Card Port Replacement: stap 8, afbeelding 1 van 2 Samsung Droid Charge SIM Card Port Replacement: stap 8, afbeelding 2 van 2
    • Your SIM card port is now unattached.
    • Remove SIM card port from motherboard.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
4 andere personen hebben deze handleiding voltooid.
Lucas Carter
190 Reputatie
1 Handleiding geschreven
Cal Poly, Team 15-44, Forte Fall 2012 Lid van Cal Poly, Team 15-44, Forte Fall 2012
CPSU-FORTE-F12S15G44
4 Leden
12 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 49
Altijd: 2,838
