Ga door naar hoofdinhoud
SEGA Genesis Flashback Controller Buttons Replacement
Wat je nodig hebt
  1. SEGA Genesis Flashback Controller Buttons Replacement, Controller Back Cover: stap 1, afbeelding 1 van 3 SEGA Genesis Flashback Controller Buttons Replacement, Controller Back Cover: stap 1, afbeelding 2 van 3 SEGA Genesis Flashback Controller Buttons Replacement, Controller Back Cover: stap 1, afbeelding 3 van 3
    • Hold the controller with the bottom plate facing up, and gently remove the top plate that is connected to the motherboard of the controller. Set the top plate aside.
    • Remove the screws on the back of the controller with the Phillips #000 screwdriver.
    • Be sure to separate the two plates with the bottom facing up, to keep the buttons from falling out.
    Vraag FixBot
    Voeg opmerking toe
  2. SEGA Genesis Flashback Controller Buttons Replacement, Controller Buttons: stap 2, afbeelding 1 van 2 SEGA Genesis Flashback Controller Buttons Replacement, Controller Buttons: stap 2, afbeelding 2 van 2
    • CAUTION: Pull gently on the rubber membranes to avoid tearing .
    • Use two fingers to remove each rubber membrane that rests on top of the buttons.
    Vraag FixBot
    Voeg opmerking toe
  3. SEGA Genesis Flashback Controller Buttons Replacement: stap 3, afbeelding 1 van 1
    • Pop the button out from the front side of the controller.
    • Pull the button out from the backside using the other hand.
    • All removable buttons can only be placed in their respective holes due to unique groove patterns on the buttons. Keep in mind where each button belongs to make re-assembly easier.
    • All buttons can be removed except for the D-Pad.
    Vraag FixBot
    Voeg opmerking toe
  4. SEGA Genesis Flashback Controller Buttons Replacement: stap 4, afbeelding 1 van 1
    • Repeat Step 3 for the remaining buttons.
    • The button should pop out seamlessly and placed to the side.
    • Repeat the prior steps in order to remove all the buttons. Set them aside in an order you will remember to where they belong.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
After completing step 4 you will need to re-assemble your controller. Do this by starting from step 2 and work backwards. Take your e-waste to an R2 or e-Stewards certified recycler.
Één andere persoon heeft deze handleiding voltooid.
Viet Nguyen
220 Reputatie
2 handleidingen geschreven
Cal Poly, Team S24-G12, Maness Spring 2018 Lid van Cal Poly, Team S24-G12, Maness Spring 2018
CPSU-MANESS-S18S24G12
4 Leden
10 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 45
Altijd: 2,239
