Ga door naar hoofdinhoud
Ryobi P277 Reversing Switch Replacement
Wat je nodig hebt
    1. Ryobi P277 Reversing Switch Replacement, Reversing Switch: stap 1, afbeelding 1 van 2 Ryobi P277 Reversing Switch Replacement, Reversing Switch: stap 1, afbeelding 2 van 2
      • Lay the device on its side with the warning label facing you.
      • Remove the eight 5 mm screws using a TR10 Torx screwdriver.
      • Separate the two halves of the casing by pulling up on the top half.
      • The two halves are still attached, so use caution when opening the device.
      Vraag FixBot
      Voeg opmerking toe
    2. Ryobi P277 Reversing Switch Replacement: stap 2, afbeelding 1 van 1
      • The reversing switch lies between the trigger and the motor.
      • Carefully remove the reversing switch from the device.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Kailyn Hammond Gouch
85 Reputatie
1 Handleiding geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 44
Altijd: 464
