Inleiding
If your Ryobi P271 cordless drill is having trouble reversing direction or seems stuck in forward mode, this guide will show you how to replace the reversing switch, a common failure point in this older model.
The reversing switch determines motor direction and is critical for tasks like backing out screws or adjusting bit alignment. A broken switch may feel loose, fail to click properly, or stop engaging altogether.
Before beginning, test the drill with a charged battery to confirm the issue isn’t related to power delivery. Also, inspect the switch for dirt or damage—sometimes a deep clean can restore function without full replacement.
This repair requires opening the drill’s housing to access internal components, so be prepared to work carefully with small plastic and metal parts. Always remove the battery before starting to ensure safety during disassembly.
Wat je nodig hebt
Detach the battery unit from the drill body by pressing the battery release buttons on both sides of the unit and pulling outwards.
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
