Ga door naar hoofdinhoud
Ryobi CSB125 Protective Shell Replacement
Wat je nodig hebt
    1. Ryobi CSB125 Protective Shell Replacement, Protective Shell: stap 1, afbeelding 1 van 1
      • Place the saw on a flat surface with the blade facing up.
      • Make sure that the saw is unplugged from any power source.
      Vraag FixBot
      Voeg opmerking toe
    2. Ryobi CSB125 Protective Shell Replacement: stap 2, afbeelding 1 van 1
      • Remove the bumper by using the T20 Torx screwdriver to loosen the M5 x 20mm screw.
      Vraag FixBot
      Voeg opmerking toe
    3. Ryobi CSB125 Protective Shell Replacement: stap 3, afbeelding 1 van 2 Ryobi CSB125 Protective Shell Replacement: stap 3, afbeelding 2 van 2
      • Use the 7”/32 allen key to loosen the 5/16-18 x 9/16 in. blade screw.
      Vraag FixBot
      Voeg opmerking toe
    4. Ryobi CSB125 Protective Shell Replacement: stap 4, afbeelding 1 van 1
      • Remove the 5/16-18 x 9/16 in. blade screw, spring washer, the outer blade washer, the blade, and the inner blade washer.
      Vraag FixBot
      Voeg opmerking toe
    5. Ryobi CSB125 Protective Shell Replacement: stap 5, afbeelding 1 van 3 Ryobi CSB125 Protective Shell Replacement: stap 5, afbeelding 2 van 3 Ryobi CSB125 Protective Shell Replacement: stap 5, afbeelding 3 van 3
      • Use the Phillips #2 screwdriver to remove the four M4x16mm screws shown.
      • You will need to rotate the protective shell around in order to access them.
      Vraag FixBot
      Voeg opmerking toe
    6. Ryobi CSB125 Protective Shell Replacement: stap 6, afbeelding 1 van 1
      • Remove the lower blade guard support assembly from the rest of the saw.
      • Remove the protective shell.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
4 andere personen hebben deze handleiding voltooid.
Curtis Melo
1.093 Reputatie
5 handleidingen geschreven
UMass Dartmouth, Team S2-G1, Barthe Fall 2019 Lid van UMass Dartmouth, Team S2-G1, Barthe Fall 2019
UMASSD-BARTHE-F19S2G1
3 Leden
4Gids Commentaar
Instructions fail at step #5. Bottom-left screw is under the plastic blade guard which blocks removal of the screw. Blade guard covers the screw no matter how it’s positioned.
Michael Bluejay - Antwoord Deel
If you wiggle the plastic you can remove
I was able to remove… be patient it does work
Adrian Isbister - Antwoord Deel
Instructions also fail at step #6. I have no idea how to remove the plastic blade guard from the axle so I can transfer it to the new (replacement) blade guard.
I also was struggling… … but if you look closely there is a thin metal ring around the center plastic ring that the spindle runs through… this has a split in it…. I used a small flat Precision screwdriver (type used to tighten reading glasses,etc)and was able to pry at the split and remove the thin metal ring.
Once removed this frees the plastic guard and it drops right out.
Just reverse to reassemble.
This works… just be patient
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 33
Altijd: 2,838
