Ga door naar hoofdinhoud
Ryobi CSB125 Power Cord Replacement
Wat je nodig hebt
  1. Ryobi CSB125 Power Cord Replacement, Power Cord: stap 1, afbeelding 1 van 1
    • Place the saw down on a flat surface with the motor facing up.
    • Make sure that the saw is unplugged from any power source.
    Vraag FixBot
    Voeg opmerking toe
  2. Ryobi CSB125 Power Cord Replacement: stap 2, afbeelding 1 van 2 Ryobi CSB125 Power Cord Replacement: stap 2, afbeelding 2 van 2
    • Use the Phillips #2 screwdriver to remove the five M4x16mm screws.
    Vraag FixBot
    Voeg opmerking toe
  3. Ryobi CSB125 Power Cord Replacement: stap 3, afbeelding 1 van 1
    • Use the Phillips #2 screwdriver to remove the two M45x35mm screws.
    Vraag FixBot
    Voeg opmerking toe
  4. Ryobi CSB125 Power Cord Replacement: stap 4, afbeelding 1 van 2 Ryobi CSB125 Power Cord Replacement: stap 4, afbeelding 2 van 2
    • To remove the plug from the saw you will need to disconnect the two wires that come from the plug.
    • Remove the black wire by unscrewing it from the trigger switch using the Phillips #2 screwdriver.
    • Remove the white wire by twisting off the plastic wire nut to separate the two white wires.
    Vraag FixBot
    Voeg opmerking toe
  5. Ryobi CSB125 Power Cord Replacement: stap 5, afbeelding 1 van 1
    • Remove the plug from the saw.
    • You may have to use the wire strippers to expose the copper on the new plug.
    • It is important that the wires are properly run in their tracks. Failure to do so could result in pinching a wire, which could damage the plug.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
5 andere personen hebben deze handleiding voltooid.
Curtis Melo
1.093 Reputatie
5 handleidingen geschreven
UMass Dartmouth, Team S2-G1, Barthe Fall 2019 Lid van UMass Dartmouth, Team S2-G1, Barthe Fall 2019
UMASSD-BARTHE-F19S2G1
3 Leden
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 17
Afgelopen 30 dagen: 43
Altijd: 2,223
