Ga door naar hoofdinhoud
RetroMini Miyoo Mini Plus Button Replacement
Wat je nodig hebt
  1. RetroMini Miyoo Mini Plus Button Replacement, Battery: stap 1, afbeelding 1 van 2 RetroMini Miyoo Mini Plus Button Replacement, Battery: stap 1, afbeelding 2 van 2
    • Lay the device face down on a flat surface.
    • You may want to lay the device on a towel or other soft surface to avoid scratching the screen.
  2. RetroMini Miyoo Mini Plus Button Replacement: stap 2, afbeelding 1 van 2 RetroMini Miyoo Mini Plus Button Replacement: stap 2, afbeelding 2 van 2
    • Use your fingernail to push in the battery compartment tab.
    • Lift the cover up to expose the battery.
  3. RetroMini Miyoo Mini Plus Button Replacement: stap 3, afbeelding 1 van 1
    • Use an opening tool to gently lift the the battery from its compartment.
    • Gently pull the battery out and set the battery next to the system, with care not to strain the attached wire.
  4. RetroMini Miyoo Mini Plus Button Replacement: stap 4, afbeelding 1 van 2 RetroMini Miyoo Mini Plus Button Replacement: stap 4, afbeelding 2 van 2
    • Pinch the white battery connector and pull it directly out of its socket.
    • Completely remove the battery.
  5. RetroMini Miyoo Mini Plus Button Replacement: stap 5, afbeelding 1 van 2 RetroMini Miyoo Mini Plus Button Replacement: stap 5, afbeelding 2 van 2
    • When you have the new battery, put the new battery wire into the connecter.
    • Place the battery back into the empty space with the wire at the bottom of the battery.
  6. RetroMini Miyoo Mini Plus Button Replacement, Button: stap 6, afbeelding 1 van 2 RetroMini Miyoo Mini Plus Button Replacement, Button: stap 6, afbeelding 2 van 2
    • Remove the four screws securing the rear case with a Phillips screwdriver.
    • Remove the two Phillips screws inside the battery compartment.
  7. RetroMini Miyoo Mini Plus Button Replacement: stap 7, afbeelding 1 van 2 RetroMini Miyoo Mini Plus Button Replacement: stap 7, afbeelding 2 van 2
    • Insert an opening tool into the seam between the front and rear case.
    • Pry the front and rear case apart.
  8. RetroMini Miyoo Mini Plus Button Replacement: stap 8, afbeelding 1 van 2 RetroMini Miyoo Mini Plus Button Replacement: stap 8, afbeelding 2 van 2
    • Gently set the rear case aside.
    • Make sure you lift the black tab on the left side of the motherboard and gently remove the ribbon cable as to not damage it when removing the motherboard from the case.
  9. RetroMini Miyoo Mini Plus Button Replacement: stap 9, afbeelding 1 van 2 RetroMini Miyoo Mini Plus Button Replacement: stap 9, afbeelding 2 van 2
    • Use an opening tool to lift the motherboard from the chassis.
  10. RetroMini Miyoo Mini Plus Button Replacement: stap 10, afbeelding 1 van 3 RetroMini Miyoo Mini Plus Button Replacement: stap 10, afbeelding 2 van 3 RetroMini Miyoo Mini Plus Button Replacement: stap 10, afbeelding 3 van 3
    • Gently set the motherboard to the side.
    • Remove the rubber button gasket.
  11. RetroMini Miyoo Mini Plus Button Replacement: stap 11, afbeelding 1 van 1
    • Remove the button(s) you want to replace.
Conclusie
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Steam Deck answers community for help.
Kaden
599 Reputatie
4 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 39
Altijd: 433
