Ga door naar hoofdinhoud
Retro-Bit Retro Duo Reset Button/Power Switch Replacement
Wat je nodig hebt
  1. Retro-Bit Retro Duo Reset Button/Power Switch Replacement, Reset Button/Power Switch: stap 1, afbeelding 1 van 3 Retro-Bit Retro Duo Reset Button/Power Switch Replacement, Reset Button/Power Switch: stap 1, afbeelding 2 van 3 Retro-Bit Retro Duo Reset Button/Power Switch Replacement, Reset Button/Power Switch: stap 1, afbeelding 3 van 3
    • With the console on its top. Remove the four 12 mm Phillips #2 screws.
    • There may be a sticker covering one, or more, of the screws. Simply remove the it before the screws.
    • Flip the console on its feet and carefully lift the top casing from the back (where the AV/S and power ports are).
    • To avoid damage, do not completely remove the top case. There is a small circuit board--which houses two LEDs-- connected to the main circuit board.
    Vraag FixBot
    Voeg opmerking toe
  2. Retro-Bit Retro Duo Reset Button/Power Switch Replacement: stap 2, afbeelding 1 van 3 Retro-Bit Retro Duo Reset Button/Power Switch Replacement: stap 2, afbeelding 2 van 3 Retro-Bit Retro Duo Reset Button/Power Switch Replacement: stap 2, afbeelding 3 van 3
    • Remove the one 6 mm Phillips #0 screw.
    • Lift the top case.
    • This step allows easy button access and prevents accidental damage.
    Vraag FixBot
    Voeg opmerking toe
  3. Retro-Bit Retro Duo Reset Button/Power Switch Replacement: stap 3, afbeelding 1 van 3 Retro-Bit Retro Duo Reset Button/Power Switch Replacement: stap 3, afbeelding 2 van 3 Retro-Bit Retro Duo Reset Button/Power Switch Replacement: stap 3, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    • Using your fingers (or precision tweezers), carefully pinch the button tabs and push through to the other side.
    • Make sure you pinch both tabs simultaneously, or the button will not pop out.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
If the problem persists after the buttons are replaced, it may be a circuit board issue. If so, please visit our guide for circuit board replacement at Retro-Bit Retro Duo Circuit Board Replacement
Truong Vo
324 Reputatie
3 handleidingen geschreven
USF Tampa, Team S4-G4, Eyestone Fall 2017 Lid van USF Tampa, Team S4-G4, Eyestone Fall 2017
USFT-EYESTONE-F17S4G4
3 Leden
10 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 13
Afgelopen 30 dagen: 47
Altijd: 1,261
