Ga door naar hoofdinhoud
iPhone 11 Charging Port Replacement
Wat je nodig hebt
  1. iPhone 11 Charging Port Replacement, Tape over any cracks: stap 1, afbeelding 1 van 3 iPhone 11 Charging Port Replacement, Tape over any cracks: stap 1, afbeelding 2 van 3 iPhone 11 Charging Port Replacement, Tape over any cracks: stap 1, afbeelding 3 van 3
    • If your iPhone has a cracked screen, keep further breakage contained and prevent bodily harm during your repair by taping over the glass.
    • Lay overlapping strips of clear packing tape over the iPhone's screen until the whole face is covered.
    • Wear safety glasses to protect your eyes from any glass shaken free during the repair.
    • If you can't get the suction cup to stick in the next few steps, fold a strong piece of tape (such as duct tape) into a handle and lift the screen with that instead.
    • If all else fails, you can superglue the suction cup to the screen.
  2. iPhone 11 Charging Port Replacement, Anti-Clamp instructions: stap 2, afbeelding 1 van 3 iPhone 11 Charging Port Replacement, Anti-Clamp instructions: stap 2, afbeelding 2 van 3 iPhone 11 Charging Port Replacement, Anti-Clamp instructions: stap 2, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    Anti-Clamp
    $24.95
    Koop
    • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
    • Slide the arms over either the left or right edge of your iPhone.
    • Position the suction cups near the bottom edge of the iPhone—one on the top, and one on the bottom.
    • Squeeze the cups together to apply suction to the desired area.
    • If you find that the surface of your iPhone is too slippery for the Anti-Clamp to hold onto, you can use tape to create a grippier surface.
  3. iPhone 11 Charging Port Replacement: stap 3, afbeelding 1 van 3 iPhone 11 Charging Port Replacement: stap 3, afbeelding 2 van 3 iPhone 11 Charging Port Replacement: stap 3, afbeelding 3 van 3
    • Pull the blue handle forward to lock the arms.
    • Turn the handle clockwise 360 degrees or until the cups start to stretch.
    • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
  4. iPhone 11 Charging Port Replacement: stap 4, afbeelding 1 van 3 iPhone 11 Charging Port Replacement: stap 4, afbeelding 2 van 3 iPhone 11 Charging Port Replacement: stap 4, afbeelding 3 van 3
    • Heat an iOpener and thread it through the arms of the Anti-Clamp.
    • You can also use a hair dryer, heat gun, or hot plate—but extreme heat can damage the display and/or internal battery, so proceed with care.
    • Fold the iOpener so it lays on the bottom edge of the iPhone.
    • Wait one minute to give the adhesive a chance to release and present an opening gap.
    • Insert an opening pick into the gap under the screen and the plastic bezel, not the screen itself.
    • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle a quarter turn.
    • Don't crank more than a quarter turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
    • Skip the next three steps.
  5. iPhone 11 Charging Port Replacement, Heat the lower edge of the phone: stap 5, afbeelding 1 van 1
    • Heating the lower edge of the iPhone helps soften the adhesive securing the display, making it easier to open.
    • Use a hairdryer or heat gun or prepare an iOpener and apply it to the lower edge of the iPhone for about a minute.
  6. iPhone 11 Charging Port Replacement: stap 6, afbeelding 1 van 2 iPhone 11 Charging Port Replacement: stap 6, afbeelding 2 van 2
    • If you're using a single suction handle, apply it to the bottom edge of the phone, while avoiding the curved portion of the glass.
  7. iPhone 11 Charging Port Replacement, Lift the display slightly: stap 7, afbeelding 1 van 3 iPhone 11 Charging Port Replacement, Lift the display slightly: stap 7, afbeelding 2 van 3 iPhone 11 Charging Port Replacement, Lift the display slightly: stap 7, afbeelding 3 van 3
    • Pull up on the suction cup with firm, constant pressure to create a slight gap between the front panel and rear case.
    • Insert an opening pick into the gap under the screen and the plastic bezelnot the screen itself.
    • The watertight adhesive holding the display in place is very strong; creating this initial gap takes a significant amount of force. If you're having a hard time opening a gap, apply more heat, and gently rock the screen up and down to weaken the adhesive until you create enough of a gap to insert your tool.
  8. iPhone 11 Charging Port Replacement, Separate the screen adhesive: stap 8, afbeelding 1 van 3 iPhone 11 Charging Port Replacement, Separate the screen adhesive: stap 8, afbeelding 2 van 3 iPhone 11 Charging Port Replacement, Separate the screen adhesive: stap 8, afbeelding 3 van 3
    • Slide the opening pick around the lower left corner and up the left edge of the iPhone, slicing through the adhesive holding the display in place.
    • Don't insert your pick more than 3 mm, as you may damage internal components.
  9. iPhone 11 Charging Port Replacement, Screen information: stap 9, afbeelding 1 van 1
    • There are delicate cables along the right edge of your iPhone. Don't insert your pick here, as you may damage the cables.
  10. iPhone 11 Charging Port Replacement: stap 10, afbeelding 1 van 3 iPhone 11 Charging Port Replacement: stap 10, afbeelding 2 van 3 iPhone 11 Charging Port Replacement: stap 10, afbeelding 3 van 3
    • Re-insert your pick at the bottom edge of the iPhone, and slide it up the right side to continue separating the adhesive.
    • Don't insert your pick more than 3 mm, as you may damage the display cables.
  11. iPhone 11 Charging Port Replacement: stap 11, afbeelding 1 van 3 iPhone 11 Charging Port Replacement: stap 11, afbeelding 2 van 3 iPhone 11 Charging Port Replacement: stap 11, afbeelding 3 van 3
    • The top edge of the display is secured with both glue and clips.
    • Gently pull the right edge of the display down slightly (in the direction of the Lightning port).
    • Insert your pick into the top-right corner of the phone.
  12. iPhone 11 Charging Port Replacement: stap 12, afbeelding 1 van 2 iPhone 11 Charging Port Replacement: stap 12, afbeelding 2 van 2
    • Continue pulling the display down (toward the Lightning port) as needed in order to make a gap large enough for the pick.
    • Slide the pick to the top left corner and cut any remaining adhesive securing the display.
    • Don't insert your pick more than 3 mm, as you may damage the Face ID sensor array.
  13. iPhone 11 Charging Port Replacement, Remove the suction cup: stap 13, afbeelding 1 van 1
    • Pull the small nub on the suction cup to detach it from the front panel.
  14. iPhone 11 Charging Port Replacement, Open the iPhone: stap 14, afbeelding 1 van 3 iPhone 11 Charging Port Replacement, Open the iPhone: stap 14, afbeelding 2 van 3 iPhone 11 Charging Port Replacement, Open the iPhone: stap 14, afbeelding 3 van 3
    • Open the iPhone by swinging the display up from the left side, like the back cover of a book.
    • Don't try to fully separate the display yet, as several fragile ribbon cables still connect it to the iPhone's logic board.
    • Prop the display up against something sturdy.
    • During reassembly, lay the display in position, align the clips along the top edge, and carefully press the top edge into place before snapping the rest of the display down. If it doesn't click easily into place, check the condition of the clips around the perimeter of the display and make sure they aren't bent.
  15. iPhone 11 Charging Port Replacement, Disconnect the battery: stap 15, afbeelding 1 van 1
    • Remove the 3 Y000 screws, then use a plastic spudger to disconnect the battery flex.
  16. iPhone 11 Charging Port Replacement, Disconnect the display: stap 16, afbeelding 1 van 1
    • Unscrew the five Y000 screws securing the main logic board shield, then remove the shield
    • Disconnect the two display cables
  17. iPhone 11 Charging Port Replacement, Taptic Engine: stap 17, afbeelding 1 van 1
    • Remove the three Philips screws securing the Taptic Engine
    • Two 1.8mm screws
    • One 1.9mm screw
    • Remove the bracket covering the Taptic Engine flex connector
    • Pry up on the connector to disconnect the cable from its socket
    • Remove the Taptic Engine
  18. iPhone 11 Charging Port Replacement, Removing the port: stap 18, afbeelding 1 van 1
    • Unscrew the two Phillips screws
    • Remove the charging port with tweezers
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Bruno Garcia
142 Reputatie
1 Handleiding geschreven
2 opmerkingen
Ummm, is it just me, or is he skipping a lot of steps after removing the screen? Lmao
Riley Steed - Antwoord
Yes. Use this video for a complete guide:
https://youtu.be/RGGxuIS4SV8?si=3BsLha9i...
Chris Cruz -
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 25
Afgelopen 7 dagen: 199
Afgelopen 30 dagen: 1,426
Altijd: 5,711
