Inleiding
If your Kenwood Chef A901D starts emitting smoke and a strong burning smell, most likely a capacitor in the motor controller is broken. Follow this guide to change the broken parts in a Kenwood Chef A901D. To do this, you need some skills in soldering. If you are new to soldering, our guide may be useful.
Wat je nodig hebt
Flip the machine upside down, so that the bottom is facing up.
Remove the two screws from the white cable strain relief strip, then remove the strip.
Remove the screw from the box covering the power wire connector.
Remove the two screws from the power wire connector block. Remove the power cable and place it aside.
In the first picture, three of the four components were already desoldered. Unscrew the triac. Note the thermal compound on the heatsink of the triac. Thermal paste will be applied to the new triac later.
In the second picture, the replacement components were all soldered back. The capacitors have a slightly different size though.
Everything is completed and ready to be reassembled. The on / off switch is soldered, the adjusting screws are screwed in and the circuit board is attached to the case with both screws.
Make sure that the pin on the support of the circuit board is engaged in the guide rail on the knob (marked by the red rectangle in the second picture). If you turn the knob, the circuit board needs to be able to move up and down a bit, otherwise the machine will not work!
Adjusting of the speed control after repair:
Turn both adjustment screws only until you can feel them flush with your fingertips on the rear side of the screw holes. Then turn the screws two turns more.
Set the speed adjuster to the lowest setting.
Plug in.
The motor should run slowly. The correct speed for the planetary drive ist 60 rpm.
Adjust the speed by turning the adjustment screws evenly.
Remove the power cord and reassemble your device following the steps in reverse order.
After adjusting the speed control, follow the steps in the reverse order for reassembly.
23 andere personen hebben deze handleiding voltooid.
Met dank aan deze vertalers:
100%
Deze vertalers helpen ons de wereld te repareren! Wil je bijdragen?
Begin met vertalen ›
43 opmerkingen
I need help. I changed the capacitors ,the resostor snd the triac, but the motor will not start. i have supply on the pink wire too. after some time the motor starts and stops. checked all the diodes found ok except one which i have changed. any ideas what i need to check? brushes ok too. can you please send me on jusmar1@hotmail.com
Hi,
To detect the issue:
you should
1- Try to shrot the main switch and the main thermo protection.
2- Try to bypass the dimmer circuit. by removing the triac from the circuit. Then short MT1 and MT2 place of the triac.
go to my instructables and find out the schematic.
https://www.instructables.com/id/Kenwood...
Regards,
SoubhiF -
@SoubhiF: Your guide ist great! Thank you for sharing.
VauWeh -
Excellent instructions and it all worked for me and saved our old Kenwood. Bought it back in 1988 now working perfectly after replacing the Diode, 2x Capacitors and resistors with the motor brushes. well done and thank you. Mike Baggot 26/04/2020
I'm lucky I could help ! Greetings from Germany.
VauWeh -
