Ga door naar hoofdinhoud
Recalibrating laptop batteries - READ FOR HP MACHINES
Wat je nodig hebt
  1. Recalibrating laptop batteries - READ FOR HP MACHINES, Log the original calibration data: stap 1, afbeelding 1 van 1
  2. Recalibrating laptop batteries - READ FOR HP MACHINES, Use your laptop: stap 2, afbeelding 1 van 3 Recalibrating laptop batteries - READ FOR HP MACHINES, Use your laptop: stap 2, afbeelding 2 van 3 Recalibrating laptop batteries - READ FOR HP MACHINES, Use your laptop: stap 2, afbeelding 3 van 3
    • Any data from this step will be lost. Only plug the laptop in to get the machine started from a BIOS lockout.
    • If you are using a Windows laptop, make sure you turn the laptop back on after the initial shutdown. Windows is designed to shut down when the battery in the laptop reports ~3% remaining capacity. This may require brief use of the power adapter if the laptop does not turn on until the charge is higher or it has AC power.
    • Use your laptop while it is discharging. You will want to do this until the computer shuts down, and if you are using Windows turn it on again until the laptop no longer turns on; this ensures a full discharge.
  3. Recalibrating laptop batteries - READ FOR HP MACHINES, Plug your laptop in: stap 3, afbeelding 1 van 2 Recalibrating laptop batteries - READ FOR HP MACHINES, Plug your laptop in: stap 3, afbeelding 2 van 2
    • While it is safe to use your laptop, the calibration accuracy may be affected.
    • Every laptop has a different charge indicator. When your laptop is fully discharged, plug it in immediately. Fully charge the laptop.
  4. Recalibrating laptop batteries - READ FOR HP MACHINES, Verify the new calibration data: stap 4, afbeelding 1 van 1
    • This procedure may "kill" end of life batteries.
    • Once you are finished, check the BMS data. The reported data should be corrected.
  5. Recalibrating laptop batteries - READ FOR HP MACHINES, (Windows 10/11) Battery health check: stap 5, afbeelding 1 van 3 Recalibrating laptop batteries - READ FOR HP MACHINES, (Windows 10/11) Battery health check: stap 5, afbeelding 2 van 3 Recalibrating laptop batteries - READ FOR HP MACHINES, (Windows 10/11) Battery health check: stap 5, afbeelding 3 van 3
    • This may not work if your battery is older, even if it is an OEM pack.
    • Run Command Prompt as an administrator. Enter powercfg /batteryreport.
    • When the report is ready, you will receive a message stating where it is located. Check the data for consistency.
  6. Recalibrating laptop batteries - READ FOR HP MACHINES, (HP UEFI) 15% lockout bypass: stap 6, afbeelding 1 van 3 Recalibrating laptop batteries - READ FOR HP MACHINES, (HP UEFI) 15% lockout bypass: stap 6, afbeelding 2 van 3 Recalibrating laptop batteries - READ FOR HP MACHINES, (HP UEFI) 15% lockout bypass: stap 6, afbeelding 3 van 3
    • Authors' note: The UI is different as this was taken in 2017; the newer HP UEFI diagnostic layout is shown in Step 10. However, the loop until error steps are still accurate.
    • This will fully discharge the battery. HP diagnostics do not check the charge capacity.
    • Plug the laptop in and turn it on; unplug it once it is on. Press ESC and select System Diagnostics.
    • Open the Component tests submenu. Select Memory or Hard Drive.
    • Select Extensive test. Choose Loop until error.
    • When the laptop shuts off, immediately recharge the battery.
  7. Recalibrating laptop batteries - READ FOR HP MACHINES, (HP Legacy BIOS) 15% lockout bypass: stap 7, afbeelding 1 van 3 Recalibrating laptop batteries - READ FOR HP MACHINES, (HP Legacy BIOS) 15% lockout bypass: stap 7, afbeelding 2 van 3 Recalibrating laptop batteries - READ FOR HP MACHINES, (HP Legacy BIOS) 15% lockout bypass: stap 7, afbeelding 3 van 3
    • DO NOT apply these settings to your primary OS. They may damage the battery.
    • Boot the laptop into a live Linux Mint Cinnamon session. Open Settings and make the following changes:
    • Open Power Management. Change When the battery is critically low to Do nothing.
    • Use the laptop until it shuts down. Everything from this session will be lost.
  8. Recalibrating laptop batteries - READ FOR HP MACHINES, (Lenovo 0190) Critical low battery bypass: stap 8, afbeelding 1 van 3 Recalibrating laptop batteries - READ FOR HP MACHINES, (Lenovo 0190) Critical low battery bypass: stap 8, afbeelding 2 van 3 Recalibrating laptop batteries - READ FOR HP MACHINES, (Lenovo 0190) Critical low battery bypass: stap 8, afbeelding 3 van 3
    • Plug the power adapter into your laptop. Allow POST to finish before unplugging the laptop.
    • Disconnect the laptop once the laptop is booted. Finish discharging the battery.
  9. Recalibrating laptop batteries - READ FOR HP MACHINES, (Optional) Label the battery: stap 9, afbeelding 1 van 2 Recalibrating laptop batteries - READ FOR HP MACHINES, (Optional) Label the battery: stap 9, afbeelding 2 van 2
    • To better track the estimated health of the battery, labeling is recommended.
    • Note the date of the recalibration.
    • Note the original charge capacity (Designed capacity).
    • Note the current capacity of the battery (Full charge capacity).
  10. Recalibrating laptop batteries - READ FOR HP MACHINES, **HP UEFI ONLY** Checking battery health: stap 10, afbeelding 1 van 3 Recalibrating laptop batteries - READ FOR HP MACHINES, **HP UEFI ONLY** Checking battery health: stap 10, afbeelding 2 van 3 Recalibrating laptop batteries - READ FOR HP MACHINES, **HP UEFI ONLY** Checking battery health: stap 10, afbeelding 3 van 3
    • If the HP UEFI diagnostics detect a persistent inaccuracy, a calibration will be recommended - this EliteBook 640 G9 does not need it, so it was not presented to me.
    • In order to check the battery health on HP laptops, you MUST use the UEFI tool as HP hides the actual heath data from the operating system. The tool can be downloaded here and written to a USB drive, or a secondary partition on the laptop - the choice is yours.
    • Run the HP diagnostics and do the following to access the battery test:
    • Locate Power in the diagnostics
    • Click on Battery and select Run once. This will take approx 2-3 minutes.
    • NOT SHOWN HERE Click on Battery details to review the health data.
  11. Recalibrating laptop batteries - READ FOR HP MACHINES, **HP UEFI ONLY** Checking battery health: stap 11, afbeelding 1 van 1
    • Click on Battery details and you will see the battery data, as well as the condition.
    • This data will tell you what condition your battery is in. The battery condition will be read in capacity left, as well as the overall health.
    • This data is helpful for gauging the condition of the battery. It provides a cycle count and the battery warranty status data, as logged by the pack in the laptop.
Eindstreep
16 andere personen hebben deze handleiding voltooid.
Nick
93.664 Reputatie
59 handleidingen geschreven
Master Techs Lid van Master Techs
Community
327 Leden
1.699 handleidingen geschreven
6 opmerkingen
Did not help at all.
I have a Windows tablet, pretty old one - previously it was showing 39% battery wear (it actually was holding for about an hour, battery itself is a bir inflated).
A couple days ago it hard crashed and wear level was reseted to 0%. Now some weird stuff started: turning off when reaching 14% battery charge, screen dimming etc.
Tried this method, and as I said in the beginning - it did not help, still shows 0% wear.
Ослик Иа - Antwoord
Late response, but some laptops and Windows based tablets (notably HP) always show 0% wear in Batteryinfoview. You need to go into the UEFI diagnostics or use use HP Support Assistant and grab it from the advanced data on HP. If it’s Dell, UEFI SupportAssist (newer systems) or ePSA (legacy).
Nothing to worry about, but another quirk like the EOL capacity reporting response on some Dell batteries. Added a note in the quirks section about this.
Nick -
I’m curious, can we send command through the I2C interface from the laptop itself to the battery and do some calibration from there? is the built-in BMS has the capability to do that?
putraadriansyah08 - Antwoord
May battery charging shows 39% and it should be always plug in (windows 11) on Asus laptop.
Badri Momeni - Antwoord
hello, my laptop is reporting 36wh battery capacity, but it stops at 0 percent for 1 hour, after 36 is drained. before it was showing 25 wh and after charging cycles it increased to 36wh. it seems to progress slowly, but in your situation, it immediately read correct value
Dimavar123 - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 95
Afgelopen 7 dagen: 622
Afgelopen 30 dagen: 3,735
Altijd: 189,444
