Ga door naar hoofdinhoud
Razer Wolverine V3 Pro Battery Replacement
Wat je nodig hebt
  1. Razer Wolverine V3 Pro Battery Replacement, Outer Shell: stap 1, afbeelding 1 van 3 Razer Wolverine V3 Pro Battery Replacement, Outer Shell: stap 1, afbeelding 2 van 3 Razer Wolverine V3 Pro Battery Replacement, Outer Shell: stap 1, afbeelding 3 van 3
    • Insert the end of a spudger or opening tool in the seam at the top of the controller.
    • Slide it around the edge to release the retaining clips.
    • Use the spudger to separate the front and back plastic outer shell of the controller.
    • Both panels should separate from the front of the bumpers.
    • This takes some patience to ensure the panels don’t crack.
    • Flip the controller so the bottom is facing up.
    • Use the spudger to separate the plastic covering on the hand grips.
    Vraag FixBot
    Voeg opmerking toe
  2. Razer Wolverine V3 Pro Battery Replacement: stap 2, afbeelding 1 van 2 Razer Wolverine V3 Pro Battery Replacement: stap 2, afbeelding 2 van 2
    • Use a JIS #0 screwdriver to remove ten 10 mm screws from the mid-frame.
    • Keep screws organized.
    Vraag FixBot
    Voeg opmerking toe
  3. Razer Wolverine V3 Pro Battery Replacement: stap 3, afbeelding 1 van 2 Razer Wolverine V3 Pro Battery Replacement: stap 3, afbeelding 2 van 2
    • Use your hands to pry the back panel of the controller.
    • You now have access to the back buttons (2 on each side).
    Vraag FixBot
    Voeg opmerking toe
  4. Razer Wolverine V3 Pro Battery Replacement: stap 4, afbeelding 1 van 2 Razer Wolverine V3 Pro Battery Replacement: stap 4, afbeelding 2 van 2
    • Remove the two JIS #0 scews securing the battery.
    Vraag FixBot
    Voeg opmerking toe
  5. Razer Wolverine V3 Pro Battery Replacement: stap 5, afbeelding 1 van 2 Razer Wolverine V3 Pro Battery Replacement: stap 5, afbeelding 2 van 2
    • Lift the actuators out of the way to access the screws beneath.
    • Use a Phillips #0 screwdriver to remove the two 6.9 mm screws under the voice coil actuators.
    Vraag FixBot
    Voeg opmerking toe
  6. Razer Wolverine V3 Pro Battery Replacement: stap 6, afbeelding 1 van 1
    • Remove the face cover from the controller.
    • The buttons may fall out in the process of removing the face cover. Be careful to not to lose them.
    • Now you have access to the internal components of the controller.
    Vraag FixBot
    Voeg opmerking toe
  7. Razer Wolverine V3 Pro Battery Replacement, Battery: stap 7, afbeelding 1 van 2 Razer Wolverine V3 Pro Battery Replacement, Battery: stap 7, afbeelding 2 van 2
    • The battery is the black rectangle shown in this figure.
    • Use a JIS #0 screwdriver to remove six screws.
    • One at each corner [6 mm].
    • One in the middle of the battery [3mm].
    • One right above the battery [4 mm].
    Vraag FixBot
    Voeg opmerking toe
  8. Razer Wolverine V3 Pro Battery Replacement: stap 8, afbeelding 1 van 3 Razer Wolverine V3 Pro Battery Replacement: stap 8, afbeelding 2 van 3 Razer Wolverine V3 Pro Battery Replacement: stap 8, afbeelding 3 van 3
    • Use the spudger to gently disconnect the small circuit board on top of the battery cover.
    • Use the angled tweezers to pull the white JST connectors out of their sockets.
    Vraag FixBot
    Voeg opmerking toe
  9. Razer Wolverine V3 Pro Battery Replacement: stap 9, afbeelding 1 van 3 Razer Wolverine V3 Pro Battery Replacement: stap 9, afbeelding 2 van 3 Razer Wolverine V3 Pro Battery Replacement: stap 9, afbeelding 3 van 3
    • Remove the battery from the controller.
    • The battery is glued to the black cover.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Malik Sharif
337 Reputatie
3 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 5
Afgelopen 7 dagen: 11
Afgelopen 30 dagen: 75
Altijd: 132
