Ga door naar hoofdinhoud
Razer DeathAdder V3 Pro USB-C Port Replacement
Wat je nodig hebt
    1. Razer DeathAdder V3 Pro USB-C Port Replacement, Scroll Wheel: stap 1, afbeelding 1 van 3 Razer DeathAdder V3 Pro USB-C Port Replacement, Scroll Wheel: stap 1, afbeelding 2 van 3 Razer DeathAdder V3 Pro USB-C Port Replacement, Scroll Wheel: stap 1, afbeelding 3 van 3
      • Use a pry tool or fingernail to carefully remove the large foot on the lower end of the mouse.
      • Remove the three 7 mm screws using a Torx T6 screwdriver.
      Vraag FixBot
      Voeg opmerking toe
    2. Razer DeathAdder V3 Pro USB-C Port Replacement: stap 2, afbeelding 1 van 2 Razer DeathAdder V3 Pro USB-C Port Replacement: stap 2, afbeelding 2 van 2
      • BEFORE YOU OPEN THE MOUSE: Be careful at this point. Both shells are connected with a cable in the front of the mouse.
      • Insert a spudger into the seam between the top and bottom shells.
      • Gently work around the edges unclipping the internal latches.
      • Slowly lift the top shell but do not remove it yet; the cables are still attached to the circuit board.
      • Carefully pull the shells apart to unplug the cable in the front.
      Vraag FixBot
      Voeg opmerking toe
    3. Razer DeathAdder V3 Pro USB-C Port Replacement: stap 3, afbeelding 1 van 2 Razer DeathAdder V3 Pro USB-C Port Replacement: stap 3, afbeelding 2 van 2
      • Using a small pry tool or your fingers, gently pop the scroll wheel up and out of its housing
      Vraag FixBot
      Voeg opmerking toe
    1. Razer DeathAdder V3 Pro USB-C Port Replacement, USB-C Port: stap 4, afbeelding 1 van 1
      • Use a T6 Torx screwdriver to remove the 5mm screws from the circuit board.
      • Unplug the battery from its connection on the right.
      • Be careful not to break the two clips that hold the PCB at the front of the mouse.
      • Remove the circuit board from the mouse.
      Vraag FixBot
      Voeg opmerking toe
    2. Razer DeathAdder V3 Pro USB-C Port Replacement: stap 5, afbeelding 1 van 1
      • Always solder in a well ventilated area.
      • Apply solder to the four anchor points on the back corners and side of the USB-C port.
      • Once the solder has melted, use tweezers to remove the USB-C port.
      • Use a solder sucker to clean the area.
      Vraag FixBot
      Voeg opmerking toe
    3. Razer DeathAdder V3 Pro USB-C Port Replacement: stap 6, afbeelding 1 van 1
      • Apply flux, then apply solder to one anchor point to help line up the new USB-C port.
      • Once the USB-C port is aligned, apply flux to the other three anchor points and solder them.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Nicholas
453 Reputatie
4 handleidingen geschreven
Texas Tech, Team 2-5, Johansen Fall 2025 Lid van Texas Tech, Team 2-5, Johansen Fall 2025
TTU-JOHANSEN-F25S2G5
5 Leden
10 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 52
Altijd: 341
