Inleiding
Use this guide to replace a broken left fan in your Razer Blade 15 Advanced Model (Early 2020) laptop.
The left fan is on the same side as the charging port.
You may need to replace the fan if your laptop is overheating.
Wat je nodig hebt
Unplug all cables, fully shut down your laptop, and close the lid.
Use a T5 Torx driver to remove the ten 3.8 mm‑long screws securing the back cover.
Apply a suction handle to the middle of the back cover's right edge, between the lower rubber foot and the middle screws.
Pull up on the suction handle to create a small gap between the back cover and the frame.
Insert an opening pick into the gap.
Angle your opening pick upward, away from the frame. Keep it angled upward as long as it's between the back cover and the frame.
Slide your opening pick around the bottom right corner of the back cover to free it from the frame.
Slide your opening pick along the front edge and around the front left corner of the back cover to free it from the frame completely.
Remove the back cover.
Lay the back cover down on its rubber feet to avoid damaging the thermal pads.
Insert the point of a spudger under the middle of the battery connector's long edge.
Lift and disconnect the battery press connector from its socket on the motherboard.
Use a spudger or your fingers to guide the Wi‑Fi card cables out of their clip on the top right corner of the fan.
Move the cables toward the right edge of the laptop and out of the way of the fan.
Push on alternating sides of the left fan cable connector with the tip of a spudger to "walk" it out of its socket.
Use a Phillips screwdriver to remove the two 5.3 mm‑long screws securing the left fan.
