Inleiding
If your Razer BlackShark V2 is producing choppy, interrupted, or no audio, your headset’s cable may be damaged (to confirm diagnoses & solutions, see Razer Blackshark V2 Troubleshooting Page, "Audio Cutting Out" or “No Audio at All”). This guide will assist you in the replacement of this component. Be mindful of which layers of the headset assembly you're taking apart and that you don't adversely damage the holds, small wires, ear cushions, ear cushions’ rubber linings or plastic ridges, or headset itself when applying pressure.
Wat je nodig hebt
Remove the four screws holding the speaker in the headset using a Phillips #1 screwdriver.
Locate the main cable after it protrudes through the opening in the headset and where the cable is attached to the motherboard.
3 andere personen hebben deze handleiding voltooid.
4 opmerkingen
any chance you have a guide to replacing the battery?
Never mind figured it out, battery is on the right earpiece... Love all your guides though!!
Cuál es el orden del cableado en el plug 3.5 porfavoor! No lo encuentro por ningún lado :(
donde consigo un repuesto del cable de los audífonos??
Where do I get a replacement headphone cable??
