Ga door naar hoofdinhoud
RCA RCT6272W23 Display Replacement
Wat je nodig hebt
    1. RCA RCT6272W23 Display Replacement, Case: stap 1, afbeelding 1 van 2 RCA RCT6272W23 Display Replacement, Case: stap 1, afbeelding 2 van 2
      • Use a Phillips #00 screwdriver to remove both 4.1 mm screws at the top of the device which hold it together.
      Vraag FixBot
      Voeg opmerking toe
    2. RCA RCT6272W23 Display Replacement: stap 2, afbeelding 1 van 2 RCA RCT6272W23 Display Replacement: stap 2, afbeelding 2 van 2
      • Press the plastic opening tool into the space between the front and back portions of the case.
      • Run it along the perimeter of the device to unhook the plastic tabs.
      • Gently pull both sides apart.
      • The speaker is connected to the back cover, so be careful when separating.
      Vraag FixBot
      Voeg opmerking toe
    1. RCA RCT6272W23 Display Replacement, Motherboard: stap 3, afbeelding 1 van 3 RCA RCT6272W23 Display Replacement, Motherboard: stap 3, afbeelding 2 van 3 RCA RCT6272W23 Display Replacement, Motherboard: stap 3, afbeelding 3 van 3
      • Use a soldering iron to remove the soldered connections on the motherboard
      • For your safety and to ensure a correct repair, be sure to exercise caution when using the soldering iron.
      • For more information about soldering, check out this guide.
      Vraag FixBot
      Voeg opmerking toe
    2. RCA RCT6272W23 Display Replacement: stap 4, afbeelding 1 van 1
      • Use a philips #00 screwdriver to unscrew the three 4.064mm screws which attach the motherboard to the front of the device.
      Vraag FixBot
      Voeg opmerking toe
    3. RCA RCT6272W23 Display Replacement: stap 5, afbeelding 1 van 2 RCA RCT6272W23 Display Replacement: stap 5, afbeelding 2 van 2
      • Use your fingers to pop the three black tabs up to release the flat plastic data transfer cables.
      Vraag FixBot
      Voeg opmerking toe
    4. RCA RCT6272W23 Display Replacement: stap 6, afbeelding 1 van 1
      • Pull up the motherboard from the rest of the body.
      Vraag FixBot
      Voeg opmerking toe
    1. RCA RCT6272W23 Display Replacement, Display: stap 7, afbeelding 1 van 1
      • Using a plastic opening tool, pry the battery off of the rest of the body.
      • The battery is attached to the display with double sided tape. It may be best to have a new strip of double sided tape to reattach the battery.
      Vraag FixBot
      Voeg opmerking toe
    2. RCA RCT6272W23 Display Replacement: stap 8, afbeelding 1 van 3 RCA RCT6272W23 Display Replacement: stap 8, afbeelding 2 van 3 RCA RCT6272W23 Display Replacement: stap 8, afbeelding 3 van 3
      • Using a spudger, separate the display surface from the front cover.
      • Be careful not to break the tabs that hold the display screen in place.
      • A second spudger may be necessary to help hold the position of the display screen.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
4 andere personen hebben deze handleiding voltooid.
Ross Pennala
214 Reputatie
1 Handleiding geschreven
Michigan Tech, Team 1-5, Lauer Spring 2015 Lid van Michigan Tech, Team 1-5, Lauer Spring 2015
MTU-LAUER-S15S1G5
2 Leden
36 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 30
Altijd: 2,641
