Ga door naar hoofdinhoud
ProntoTec Axius Motherboard Replacement
Wat je nodig hebt
    1. ProntoTec Axius Motherboard Replacement, Motherboard: stap 1, afbeelding 1 van 1
      • Make sure the device is completely turned off before you begging taking it apart to avoid electrocution risks.
      • Place the tablet face-up on a flat table.
      Vraag FixBot
      Voeg opmerking toe
    2. ProntoTec Axius Motherboard Replacement: stap 2, afbeelding 1 van 1
      • Starting near the headphone port, fit the flat end of the spudger in between the screen and back case.
      • Pry the back case from the screen around each point on the device to release the clips securing the case halves to each other.
      Vraag FixBot
      Voeg opmerking toe
    3. ProntoTec Axius Motherboard Replacement: stap 3, afbeelding 1 van 1
      • Gently remove the back case of the device and lay it in a flat surface as shown in the photo.
      • Make sure not to sever the wires (red and black) connected to the speaker that is located in the back case.
      Vraag FixBot
      Voeg opmerking toe
    4. ProntoTec Axius Motherboard Replacement: stap 4, afbeelding 1 van 2 ProntoTec Axius Motherboard Replacement: stap 4, afbeelding 2 van 2
      • Remove only the yellow tape that touches the motherboard
      • Be careful not to cut or damage the wires (red and black) that connect the battery to the motherboard.
      Vraag FixBot
      Voeg opmerking toe
    5. ProntoTec Axius Motherboard Replacement: stap 5, afbeelding 1 van 3 ProntoTec Axius Motherboard Replacement: stap 5, afbeelding 2 van 3 ProntoTec Axius Motherboard Replacement: stap 5, afbeelding 3 van 3
      • Use a Phillips screwdriver (PH00) to unscrew the two screws that connects the motherboard to the device
      • Be careful not to cut or damage the wires (red and black) that connect the motherboard to the battery.
      Vraag FixBot
      Voeg opmerking toe
    6. ProntoTec Axius Motherboard Replacement: stap 6, afbeelding 1 van 2 ProntoTec Axius Motherboard Replacement: stap 6, afbeelding 2 van 2
      • Using a soldering iron, desolder the contact points of the speaker, battery and screen on the motherboard
      • If soldering is new to you, check out this helpful guide on soldering and desoldering connections.
      • Use pliers to pull the wire from the board
      Vraag FixBot
      Voeg opmerking toe
    7. ProntoTec Axius Motherboard Replacement: stap 7, afbeelding 1 van 2 ProntoTec Axius Motherboard Replacement: stap 7, afbeelding 2 van 2
      • Using the spudger, disconnect the ribbon cable connecting the camera to the motherboard
      Vraag FixBot
      Voeg opmerking toe
    8. ProntoTec Axius Motherboard Replacement: stap 8, afbeelding 1 van 3 ProntoTec Axius Motherboard Replacement: stap 8, afbeelding 2 van 3 ProntoTec Axius Motherboard Replacement: stap 8, afbeelding 3 van 3
      • Using the spudger, push the black tabs towards the ribbon cable to unlock the ribbon cables that connect the screen to the motherboard.
      • Gently pull and remove the ribbon cables from the motherboard
      Vraag FixBot
      Voeg opmerking toe
    9. ProntoTec Axius Motherboard Replacement: stap 9, afbeelding 1 van 2 ProntoTec Axius Motherboard Replacement: stap 9, afbeelding 2 van 2
      • Using the flat side of the spudger, lift up the mother board to disconnect from the screen.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Estelle Hatem
156 Reputatie
1 Handleiding geschreven
UMass Dartmouth, Team 5-3, Martin Fall 2016 Lid van UMass Dartmouth, Team 5-3, Martin Fall 2016
UMASSD-MARTIN-F16S5G3
3 Leden
10 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 34
Altijd: 641
