Ga door naar hoofdinhoud
Porter-Cable PCC710B Lever Assembly Replacement
Wat je nodig hebt
    1. Porter-Cable PCC710B Lever Assembly Replacement, Lever assembly: stap 1, afbeelding 1 van 1
      • Place the tool on its side so the orange and white warning label barcodes are facing up.
      • The lever and battery base of the tool should point toward you.
      Vraag FixBot
      Voeg opmerking toe
    2. Porter-Cable PCC710B Lever Assembly Replacement: stap 2, afbeelding 1 van 3 Porter-Cable PCC710B Lever Assembly Replacement: stap 2, afbeelding 2 van 3 Porter-Cable PCC710B Lever Assembly Replacement: stap 2, afbeelding 3 van 3
      • Use a 5.5 mm nut driver to unscrew the Hex nut.
      • If the Hex nut is not unscrewing easily- you can use a 3 mm Hex head screwdriver to hold the other side of the screw still.
      Vraag FixBot
      Voeg opmerking toe
    3. Porter-Cable PCC710B Lever Assembly Replacement: stap 3, afbeelding 1 van 1
      • Flip the tool over and remove the black screw holding the tool together.
      • Get a good grip on the screw by using pliers to pull the screw out of the tool.
      Vraag FixBot
      Voeg opmerking toe
    4. Porter-Cable PCC710B Lever Assembly Replacement: stap 4, afbeelding 1 van 3 Porter-Cable PCC710B Lever Assembly Replacement: stap 4, afbeelding 2 van 3 Porter-Cable PCC710B Lever Assembly Replacement: stap 4, afbeelding 3 van 3
      • Pinch the lever with your fingers and pull it up and away from the tool. The lever pops right off! You can squeeze on the lever, and it will come off just as easily.
      • When replacing your new lever assembly, make sure the black torsion (the black staple-like hinge) is oriented correctly.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
To reassemble your device, follow instruction steps 3 to 1 in reverse order.
Alex Zapata
665 Reputatie
7 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 13
Altijd: 472
