Ga door naar hoofdinhoud
Polaroid PTAB7XC Screen Replacement
Wat je nodig hebt
    1. Polaroid PTAB7XC Screen Replacement, Screen: stap 1, afbeelding 1 van 2 Polaroid PTAB7XC Screen Replacement, Screen: stap 1, afbeelding 2 van 2
      • Remove the two 7 mm screws on the top of the device using a J00 Phillips screwdriver and by turning the screws counterclockwise.
      • If the screw heads have corroded or been stripped, it may be necessary to use a larger screwdriver head, such as the J0.
      Vraag FixBot
      Voeg opmerking toe
    2. Polaroid PTAB7XC Screen Replacement: stap 2, afbeelding 1 van 3 Polaroid PTAB7XC Screen Replacement: stap 2, afbeelding 2 van 3 Polaroid PTAB7XC Screen Replacement: stap 2, afbeelding 3 van 3
      • Pry the seam between the screen and the case on all four sides with a large plastic opening tool until the plastic case comes off.
      • Lift the device off of the case and flip over the device so that it sits screen side down.
      • The device is now free from the plastic casing.
      • The power and/or volume buttons may fall out at this point. There is no problem with this; however, be sure to remember to reinstall them when reassembling the device.
      Vraag FixBot
      Voeg opmerking toe
    3. Polaroid PTAB7XC Screen Replacement: stap 3, afbeelding 1 van 2 Polaroid PTAB7XC Screen Replacement: stap 3, afbeelding 2 van 2
      Gereedschap gebruikt in deze stap:
      Plastic Cards
      $2.99
      • Wedge a plastic card beneath the battery unit.
      • Wiggle the card side to side and up and down gently until the glue sealing the battery to the device is broken.
      • Do not rupture the battery; it poses a serious safety hazard.
      • There is a plastic bag around the battery; if torn or stretched, there is no safety hazard.
      Vraag FixBot
      Voeg opmerking toe
    4. Polaroid PTAB7XC Screen Replacement: stap 4, afbeelding 1 van 3 Polaroid PTAB7XC Screen Replacement: stap 4, afbeelding 2 van 3 Polaroid PTAB7XC Screen Replacement: stap 4, afbeelding 3 van 3
      • Desolder the following components from the motherboard.
      • Desolder from the motherboard the red wire that connects to the speaker unit.
      • Desolder from the motherboard the black wire that connects to the speaker unit.
      • Desolder from the motherboard the gray wire that runs along the edge of the device.
      • The motherboard will now be detached from any wires connecting to the device except for those attached to the battery.
      Vraag FixBot
      Voeg opmerking toe
    5. Polaroid PTAB7XC Screen Replacement: stap 5, afbeelding 1 van 3 Polaroid PTAB7XC Screen Replacement: stap 5, afbeelding 2 van 3 Polaroid PTAB7XC Screen Replacement: stap 5, afbeelding 3 van 3
      • Use tweezers to unstick the medium width yellow ribbon cable from the motherboard.
      • Use a small opening tool to slide the two small black holding clips off of the white connector to which the medium width yellow ribbon cable is attached.
      • Use your fingers to gently pull the medium width yellow ribbon cable out of the white connector.
      • Repeat the last two actions to disconnect the narrower yellow ribbon cable and the wider yellow ribbon cable from the motherboard.
      • The motherboard and battery will now be detached from any ribbon cables connecting to the device.
      Vraag FixBot
      Voeg opmerking toe
    6. Polaroid PTAB7XC Screen Replacement: stap 6, afbeelding 1 van 3 Polaroid PTAB7XC Screen Replacement: stap 6, afbeelding 2 van 3 Polaroid PTAB7XC Screen Replacement: stap 6, afbeelding 3 van 3
      • Use the PH000 screwdriver remove the four 5 mm screws along the bottom edge of the motherboard, turning them counterclockwise.
      Vraag FixBot
      Voeg opmerking toe
    7. Polaroid PTAB7XC Screen Replacement: stap 7, afbeelding 1 van 1
      • Lift the motherboard and battery out of the device using your hands.
      • The back of the display and the speaker unit will now be visible and accessible
      Vraag FixBot
      Voeg opmerking toe
    8. Polaroid PTAB7XC Screen Replacement: stap 8, afbeelding 1 van 1
      • Remove the 5mm screw that holds the speaker unit on to the display unit using a J000 screwdriver, turning the screws counterclockwise.
      Vraag FixBot
      Voeg opmerking toe
    9. Polaroid PTAB7XC Screen Replacement: stap 9, afbeelding 1 van 1
      • Using thumb and forefinger, remove the speaker unit from the device
      Vraag FixBot
      Voeg opmerking toe
    10. Polaroid PTAB7XC Screen Replacement: stap 10, afbeelding 1 van 1
      • Using a J000 Philips head screwdriver, remove the two 5mm screws that hold the display unit down at the bottom of the device, turning the screws counterclockwise.
      Vraag FixBot
      Voeg opmerking toe
    11. Polaroid PTAB7XC Screen Replacement: stap 11, afbeelding 1 van 1
      • Lift the small black display protector that was between the screws and the display unit using your forefinger and thumb.
      Vraag FixBot
      Voeg opmerking toe
    12. Polaroid PTAB7XC Screen Replacement: stap 12, afbeelding 1 van 1
      • Using both hands, lift up the device.
      • Using your fingers, push upward from below on the screen until the screen and display unit pop out of the black plastic frame.
      • The screen and display unit should now be separated from the plastic casing.
      • Set the screen and display unit screen-side down.
      Vraag FixBot
      Voeg opmerking toe
    13. Polaroid PTAB7XC Screen Replacement: stap 13, afbeelding 1 van 2 Polaroid PTAB7XC Screen Replacement: stap 13, afbeelding 2 van 2
      • Wedge the large plastic opening tool into one of the notches on the edge of the screen and display unit.
      • Pry until a small tab pops out of the notch.
      • Repeat on every notch around the edge of the screen and display unit.
      Vraag FixBot
      Voeg opmerking toe
    14. Polaroid PTAB7XC Screen Replacement: stap 14, afbeelding 1 van 1
      • Using your fingers, lift the display unit off of the screen.
      • The screen is now replaceable.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Één andere persoon heeft deze handleiding voltooid.
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 23
Altijd: 773
