Ga door naar hoofdinhoud
Polaroid PTAB7XC Battery Replacement
Wat je nodig hebt
    1. Polaroid PTAB7XC Battery Replacement, Battery: stap 1, afbeelding 1 van 2 Polaroid PTAB7XC Battery Replacement, Battery: stap 1, afbeelding 2 van 2
      • Remove the two 7 mm screws on the top of the device using a J00 Phillips screwdriver, turning them counterclockwise.
      • If the screw heads have corroded or been stripped, it may be necessary to use a larger screwdriver head, such as the J0.
      Vraag FixBot
      Voeg opmerking toe
    2. Polaroid PTAB7XC Battery Replacement: stap 2, afbeelding 1 van 3 Polaroid PTAB7XC Battery Replacement: stap 2, afbeelding 2 van 3 Polaroid PTAB7XC Battery Replacement: stap 2, afbeelding 3 van 3
      • Pry the seam between the screen and the case on all four sides with a large plastic opening tool until the plastic case comes off.
      • Lift the device off of the case and flip over the device so that it sits screen side down.
      • The device is now free from the plastic casing.
      • The power and/or volume buttons may fall out at this point. There is no problem with this; however, be sure to remember to reinstall them when reassembling the device.
      Vraag FixBot
      Voeg opmerking toe
    3. Polaroid PTAB7XC Battery Replacement: stap 3, afbeelding 1 van 2 Polaroid PTAB7XC Battery Replacement: stap 3, afbeelding 2 van 2
      Gereedschap gebruikt in deze stap:
      Plastic Cards
      $2.99
      • Wedge a plastic card beneath the battery unit.
      • Wiggle the card side to side and up and down gently until the glue sealing the battery to the device is broken.
      • Do not rupture the battery; it poses a serious safety hazard.
      • There is a plastic bag around the battery; if torn or stretched, there is no safety hazard.
      Vraag FixBot
      Voeg opmerking toe
    4. Polaroid PTAB7XC Battery Replacement: stap 4, afbeelding 1 van 3 Polaroid PTAB7XC Battery Replacement: stap 4, afbeelding 2 van 3 Polaroid PTAB7XC Battery Replacement: stap 4, afbeelding 3 van 3
      • Set the device on a heat safe surface.
      • Desolder from the motherboard the red wire that connects to the battery unit.
      • Desolder from the motherboard the black wire that connects to the battery unit.
      • Lift the battery out of the device using your hands.
      • The battery is now free from the device.
      • If either of the wires do not come completely free when desoldering, use tweezers to gently pull them free.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
4 andere personen hebben deze handleiding voltooid.
1Gids Commentaar
This tablet has the exact same setup as the 2011-2012 nextbook part might be interchangeable with this tablet .
Walker wallace - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 36
Altijd: 2,543
