Ga door naar hoofdinhoud
Polaroid Flash Unit Shell Replacement
Wat je nodig hebt
    1. Polaroid Flash Unit Shell Replacement, Before you begin: stap 1, afbeelding 1 van 1
      • If you have any film left, take some photos! Then remove the cartridge. Disassembly will expose any leftover film.
      • Unplug all cables from your camera.
      Vraag FixBot
      Voeg opmerking toe
    2. Polaroid Flash Unit Shell Replacement, Open your camera: stap 2, afbeelding 1 van 2 Polaroid Flash Unit Shell Replacement, Open your camera: stap 2, afbeelding 2 van 2
      • Fully open the flash unit at the front of your camera.
      Vraag FixBot
      Voeg opmerking toe
    3. Polaroid Flash Unit Shell Replacement, Remove the screw cover: stap 3, afbeelding 1 van 3 Polaroid Flash Unit Shell Replacement, Remove the screw cover: stap 3, afbeelding 2 van 3 Polaroid Flash Unit Shell Replacement, Remove the screw cover: stap 3, afbeelding 3 van 3
      • Slide the tip of an opening pick under the right edge of the screw cover, near the flash.
      • Leave the pick inserted under the cover for the next step.
      Vraag FixBot
      Voeg opmerking toe
    4. Polaroid Flash Unit Shell Replacement: stap 4, afbeelding 1 van 3 Polaroid Flash Unit Shell Replacement: stap 4, afbeelding 2 van 3 Polaroid Flash Unit Shell Replacement: stap 4, afbeelding 3 van 3
      • Slide the cover towards the flash to release the clips securing it.
      • Your pick might fall out—that's fine.
      • Pull the cover straight away from the camera and remove it.
      Vraag FixBot
      Voeg opmerking toe
    5. Polaroid Flash Unit Shell Replacement, Remove the flash unit shell screws: stap 5, afbeelding 1 van 3 Polaroid Flash Unit Shell Replacement, Remove the flash unit shell screws: stap 5, afbeelding 2 van 3 Polaroid Flash Unit Shell Replacement, Remove the flash unit shell screws: stap 5, afbeelding 3 van 3
      • Hold the flash unit open with one hand.
      • With your free hand, use a Phillips screwdriver to remove the three 5.9 mm‑long screws securing the flash unit shell.
      Vraag FixBot
      Voeg opmerking toe
    6. Polaroid Flash Unit Shell Replacement, Remove the flash unit shell: stap 6, afbeelding 1 van 3 Polaroid Flash Unit Shell Replacement, Remove the flash unit shell: stap 6, afbeelding 2 van 3 Polaroid Flash Unit Shell Replacement, Remove the flash unit shell: stap 6, afbeelding 3 van 3
      • Fully close the flash unit for a better grip on the shell.
      • Secure the camera with one hand, and firmly grip the flash unit shell with the other.
      • Lift the right edge of the shell (the side closest to the charging port) to release the clips securing it.
      • You should feel and hear "clicks" as the clips release.
      • Pull the shell up and away from the camera to remove it.
      • During reassembly, put the shell in place and push down firmly to engage the clips.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Spencer Day
197.796 Reputatie
1.243 handleidingen geschreven
iFixit Lid van iFixit
Staff
123 Leden
46.859 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 25
Altijd: 411
