Ga door naar hoofdinhoud
Polaroid A10 Battery Replacement
Wat je nodig hebt
    1. Polaroid A10 Battery Replacement, Back Cover: stap 1, afbeelding 1 van 3 Polaroid A10 Battery Replacement, Back Cover: stap 1, afbeelding 2 van 3 Polaroid A10 Battery Replacement, Back Cover: stap 1, afbeelding 3 van 3
      • Begin by having the side with volume and power button face up towards you.
      • Insert a plastic opening tool between the display and the back cover.
      • Once you have one plastic opening tool in, you can insert another one. While holding one in place, slide the other along the gap to release the tabs.
      • It is easier to remove the back cover, if the display screen is faced down.
      • The tabs must be released from all four sides before removing the back cover.
      Vraag FixBot
      Voeg opmerking toe
    1. Polaroid A10 Battery Replacement, Battery: stap 2, afbeelding 1 van 3 Polaroid A10 Battery Replacement, Battery: stap 2, afbeelding 2 van 3 Polaroid A10 Battery Replacement, Battery: stap 2, afbeelding 3 van 3
      Gereedschap gebruikt in deze stap:
      Plastic Cards
      $2.99
      • Begin by inserting the flat end of a spudger underneath the battery to separate the glue from the battery.
      • It is better to use a plastic card if you have one.
      • Gently lift up the battery as you continue to separate the glue from the battery.
      • Lift up just enough to see where the glue is, so that you don't bend the battery.
      • Once the glue has been separated, gently lift up the battery and you will notice two wires attached to the motherboard.
      Vraag FixBot
      Voeg opmerking toe
    2. Polaroid A10 Battery Replacement: stap 3, afbeelding 1 van 3 Polaroid A10 Battery Replacement: stap 3, afbeelding 2 van 3 Polaroid A10 Battery Replacement: stap 3, afbeelding 3 van 3
      Vraag FixBot
      Voeg opmerking toe
    3. Polaroid A10 Battery Replacement: stap 4, afbeelding 1 van 1
      • Gently lift the battery up and out of the device.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Één andere persoon heeft deze handleiding voltooid.
armando
150 Reputatie
1 Handleiding geschreven
UW Tacoma, Team 3-3, Rose Winter 2015 Lid van UW Tacoma, Team 3-3, Rose Winter 2015
UWT-ROSE-W15S3G3
4 Leden
12 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 11
Afgelopen 30 dagen: 28
Altijd: 1,152
