Ga door naar hoofdinhoud
PlayStation Power Supply Replacement
Wat je nodig hebt
  1. PlayStation Power Supply Replacement, Open the Console: stap 1, afbeelding 1 van 1
    • Before you begin, make sure the console is turned off and unplugged.
    • Turn the console upside down and remove the five 15.8 mm-long Phillips #1 screws.
    Vraag FixBot
    Voeg opmerking toe
  2. PlayStation Power Supply Replacement: stap 2, afbeelding 1 van 2 PlayStation Power Supply Replacement: stap 2, afbeelding 2 van 2
    • While holding the top and bottom halves of the console together, flip the console back over. Lift the top cover straight up to remove it.
    Vraag FixBot
    Voeg opmerking toe
  3. PlayStation Power Supply Replacement, Unplug the Power Supply: stap 3, afbeelding 1 van 2 PlayStation Power Supply Replacement, Unplug the Power Supply: stap 3, afbeelding 2 van 2
    • Pull the power supply cable straight up and out of its socket on the power supply to disconnect it.
    Vraag FixBot
    Voeg opmerking toe
  4. PlayStation Power Supply Replacement, Remove the Power Supply: stap 4, afbeelding 1 van 1
    • Remove the two 14 mm-long Phillips #1 screws securing the power supply to the bottom case.
    Vraag FixBot
    Voeg opmerking toe
  5. PlayStation Power Supply Replacement: stap 5, afbeelding 1 van 2 PlayStation Power Supply Replacement: stap 5, afbeelding 2 van 2
    • Lift the outer edge of the power supply slightly, then rotate the whole power supply away from the small clip on its inner edge to remove the power supply.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
28 andere personen hebben deze handleiding voltooid.
Craig Lloyd
42.948 Reputatie
82 handleidingen geschreven
4Gids Commentaar
Since working with the power supply, it's wise to state in writing to disconnect the AC cord, in addition to showing it disconnected as you have.
Collin - Antwoord Deel
Once I take out my power supply how do I fix the issue with the power supply
Tiago - Antwoord Deel
im done removing the power supply so whats next???btw i accidentally plugged my ps1 110v to 220v how to fix that issue???
kendofox - Antwoord Deel
Before anything unplug your PlayStation and try the power button couple a times to turn on the PlayStation.
Just check the fuse with a multimeter. It is a cylindrical tube with metal on it’s two corners. The easy way is to check continuity with a mutimeter which is a symbol with a speaker on it. Touch red and black probes and you will hear a beep. Connect the two ends of the fuse and if it beeps then fuse is ok. You can even check it while fuse is on the board. If ok and PlayStation is not working then there is a problem somewhere else on the power board, mostly…
Good Luck!!
gUru0026 - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 6
Afgelopen 7 dagen: 44
Afgelopen 30 dagen: 207
Altijd: 31,699
