Inleiding
Follow this guide to replace a broken or faulty fan in your PlayStation 5 Slim.
If your fan isn't spinning, is spinning very slowly, or is making very loud noises, you may need to replace it.
You can also use this guide to clean out a dusty or dirty fan.
Before purchasing a replacement fan, it's a good idea to remove your current fan and clean off any dust, dirt, hair, or grime that may have accumulated—it's possible this alone is the problem. If the fan still shows signs of being faulty after cleaning, then consider purchasing a replacement.
Wat je nodig hebt
Shut down your console.
Unplug all cables and accessories.
Remove any stands supporting your device.
Lay your PlayStation on its side so the right side covers are facing up.
Firmly pull up the front edge of the cover to release the clips.
Remove the cover.
Use your fingers to remove the plastic cover.
Gently pull the fan cables out from under their plastic clip on the frame.
Firmly grip the fan cables white connector head and pull it straight up and out of its socket.
Use a T8 Torx Security screwdriver to remove the four screws securing the fan:
One 11.6 mm‑long screw
One 31.2 mm‑long screw
Two 21.3 mm‑long screws
Use your fingers to grab the fan by its vents, and lift it straight up to remove it.
Lift the fan straight up and remove it.
