Ga door naar hoofdinhoud
PlayStation 5 Pro Fan Replacement
Wat je nodig hebt
  1. PlayStation 5 Pro Fan Replacement, Before you begin: stap 1, afbeelding 1 van 3 PlayStation 5 Pro Fan Replacement, Before you begin: stap 1, afbeelding 2 van 3 PlayStation 5 Pro Fan Replacement, Before you begin: stap 1, afbeelding 3 van 3
    • Before starting your repair:
    • Shut down your PlayStation and unplug all cables and accessories.
    • Remove any stands supporting your console and lay it down so the right side is facing up.
  2. PlayStation 5 Pro Fan Replacement, Remove the fan and SSD cover: stap 2, afbeelding 1 van 3 PlayStation 5 Pro Fan Replacement, Remove the fan and SSD cover: stap 2, afbeelding 2 van 3 PlayStation 5 Pro Fan Replacement, Remove the fan and SSD cover: stap 2, afbeelding 3 van 3
    • The cover is secured with hooks along the back edge and clips along the front edge.
    • Firmly pull up the front edge of the smaller, upper cover to release the clips.
    • You'll hear distinct "pops" as the clips disengage.
    • Remove the cover.
    • To reinstall the cover, place the hooks into their cutouts along the rear edge and firmly press the front edge of the cover into place to re‑engage the two clips.
  3. PlayStation 5 Pro Fan Replacement, Remove the fan cables cover: stap 3, afbeelding 1 van 3 PlayStation 5 Pro Fan Replacement, Remove the fan cables cover: stap 3, afbeelding 2 van 3 PlayStation 5 Pro Fan Replacement, Remove the fan cables cover: stap 3, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    Tesa 61395 Tape
    $5.99
    • Use your fingers to remove the plastic cover hiding the fan cables connector.
    • The cover is secured with light adhesive.
    • During reassembly, press the piece of plastic back into place to secure it with the leftover adhesive. If it isn't sticking, use strips of double-sided tape to secure it.
  4. PlayStation 5 Pro Fan Replacement, Free the fan cables: stap 4, afbeelding 1 van 2 PlayStation 5 Pro Fan Replacement, Free the fan cables: stap 4, afbeelding 2 van 2
    • Gently pull the fan cables out from under their plastic clip on the frame.
  5. PlayStation 5 Pro Fan Replacement, Disconnect the fan: stap 5, afbeelding 1 van 2 PlayStation 5 Pro Fan Replacement, Disconnect the fan: stap 5, afbeelding 2 van 2
    • Firmly grip the fan cables' white connector head and pull it straight up and out of its socket.
    • If you're having trouble, grip the cables just above the connector head and gently pull.
    • During reassembly, align the connector over its socket and push down on the edges with a clean fingernail or the flat end of a spudger until it slides fully into its socket.
  6. PlayStation 5 Pro Fan Replacement, Remove the fan screws: stap 6, afbeelding 1 van 2 PlayStation 5 Pro Fan Replacement, Remove the fan screws: stap 6, afbeelding 2 van 2
    FixMat
    $36.95
    • Use a T8 Torx Security screwdriver to remove the four screws securing the fan:
    • One 31.7 mm‑long screw
    • Two 21.5 mm‑long screws
    • One 11.5 mm‑long screw
  7. PlayStation 5 Pro Fan Replacement, Remove the fan: stap 7, afbeelding 1 van 2 PlayStation 5 Pro Fan Replacement, Remove the fan: stap 7, afbeelding 2 van 2
    • Use your fingers to grab the fan by its vents and lift it straight up to remove it.
    • If you're using this guide to clean your fan, use compressed air and a clean cloth to remove any dust or dirt.
    • During reassembly, insert the fan so its cables are near their connector.
Conclusie
Spencer Day
95.715 Reputatie
662 handleidingen geschreven
iFixit Lid van iFixit
Staff
118 Leden
19.545 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 9
Afgelopen 7 dagen: 62
Afgelopen 30 dagen: 235
Altijd: 526
