Ga door naar hoofdinhoud
PlayStation 5 Power and Eject Button Board Replacement
Wat je nodig hebt
  1. PlayStation 5 Power and Eject Button Board Replacement, Remove the stand screw: stap 1, afbeelding 1 van 1
    • If your PlayStation 5 is in its vertical orientation, flip it upside down so the stand is facing up.
    • If your PlayStation 5 is in its horizontal orientation, skip to Step 6.
    • Work on a flat surface to prevent your PlayStation from falling over.
    • Use a coin or a flathead screwdriver to remove the 26.5 mm-long stand screw.
  2. PlayStation 5 Power and Eject Button Board Replacement, Remove the vertical stand: stap 2, afbeelding 1 van 2 PlayStation 5 Power and Eject Button Board Replacement, Remove the vertical stand: stap 2, afbeelding 2 van 2
    • Lift straight up to remove the stand.
  3. PlayStation 5 Power and Eject Button Board Replacement, Store the stand screw: stap 3, afbeelding 1 van 2 PlayStation 5 Power and Eject Button Board Replacement, Store the stand screw: stap 3, afbeelding 2 van 2
    • Insert the screw into the cubby on the bottom of the stand.
  4. PlayStation 5 Power and Eject Button Board Replacement, Cap the screw hole: stap 4, afbeelding 1 van 3 PlayStation 5 Power and Eject Button Board Replacement, Cap the screw hole: stap 4, afbeelding 2 van 3 PlayStation 5 Power and Eject Button Board Replacement, Cap the screw hole: stap 4, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    Koop
    • Use a pair of tweezers or your fingernail to remove the cap from the cubby.
    • Use your finger to press the cap into the screw hole.
  5. PlayStation 5 Power and Eject Button Board Replacement, Close the cubby: stap 5, afbeelding 1 van 3 PlayStation 5 Power and Eject Button Board Replacement, Close the cubby: stap 5, afbeelding 2 van 3 PlayStation 5 Power and Eject Button Board Replacement, Close the cubby: stap 5, afbeelding 3 van 3
    • Twist the stand counterclockwise to close the cubby.
  6. PlayStation 5 Power and Eject Button Board Replacement, Remove the horizontal stand: stap 6, afbeelding 1 van 2 PlayStation 5 Power and Eject Button Board Replacement, Remove the horizontal stand: stap 6, afbeelding 2 van 2
    • If your PlayStation 5 is in its horizontal orientation, rest it on its face with the charging port facing up.
    • Lift the stand straight up to remove it.
  7. PlayStation 5 Power and Eject Button Board Replacement, Remove the right faceplate: stap 7, afbeelding 1 van 3 PlayStation 5 Power and Eject Button Board Replacement, Remove the right faceplate: stap 7, afbeelding 2 van 3 PlayStation 5 Power and Eject Button Board Replacement, Remove the right faceplate: stap 7, afbeelding 3 van 3
    • Flip the device over so that the USB and ethernet ports are on the left side from your perspective.
    • Lift up the corner of the faceplate to unclip it from the case.
  8. PlayStation 5 Power and Eject Button Board Replacement: stap 8, afbeelding 1 van 2 PlayStation 5 Power and Eject Button Board Replacement: stap 8, afbeelding 2 van 2
    • While lifting up the corner, slide the faceplate towards the bottom of the device.
    • Remove the right faceplate.
  9. PlayStation 5 Power and Eject Button Board Replacement, Pry up the grille: stap 9, afbeelding 1 van 3 PlayStation 5 Power and Eject Button Board Replacement, Pry up the grille: stap 9, afbeelding 2 van 3 PlayStation 5 Power and Eject Button Board Replacement, Pry up the grille: stap 9, afbeelding 3 van 3
    • Insert the flat end of a spudger underneath the grille and into the gap above the fan.
    • Lift up with the spudger to pry the grille away from the case.
  10. PlayStation 5 Power and Eject Button Board Replacement, Remove the grille: stap 10, afbeelding 1 van 2 PlayStation 5 Power and Eject Button Board Replacement, Remove the grille: stap 10, afbeelding 2 van 2
    • Lift the grille away from the case to remove it.
  11. PlayStation 5 Power and Eject Button Board Replacement, Remove the fan shroud screws: stap 11, afbeelding 1 van 1
    Magnetic Project Mat
    $19.95
    Koop
    • Use a TR8 Torx security driver to remove the four screws securing the fan shroud to the case:
    • Two 23.3 mm-long screws
    • One 11.4 mm-long screw
    • One 31 mm-long screw
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your console.
  12. PlayStation 5 Power and Eject Button Board Replacement, Remove the fan shroud: stap 12, afbeelding 1 van 2 PlayStation 5 Power and Eject Button Board Replacement, Remove the fan shroud: stap 12, afbeelding 2 van 2
    • Lift the fan shroud straight up to remove it.
  13. PlayStation 5 Power and Eject Button Board Replacement, Remove the wire cover: stap 13, afbeelding 1 van 3 PlayStation 5 Power and Eject Button Board Replacement, Remove the wire cover: stap 13, afbeelding 2 van 3 PlayStation 5 Power and Eject Button Board Replacement, Remove the wire cover: stap 13, afbeelding 3 van 3
    • Insert the flat end of a spudger beneath the black wire cover and into the gap above the fan wires.
    • Pry only on the wire cover, not on the fan wires themselves.
    • Use the spudger to peel up the wire cover until you can grip it with your fingers.
  14. PlayStation 5 Power and Eject Button Board Replacement: stap 14, afbeelding 1 van 3 PlayStation 5 Power and Eject Button Board Replacement: stap 14, afbeelding 2 van 3 PlayStation 5 Power and Eject Button Board Replacement: stap 14, afbeelding 3 van 3
    • Use your fingers to peel off the wire cover.
  15. PlayStation 5 Power and Eject Button Board Replacement, Disconnect the fan: stap 15, afbeelding 1 van 2 PlayStation 5 Power and Eject Button Board Replacement, Disconnect the fan: stap 15, afbeelding 2 van 2
    • Use your fingers to grip the edges of the fan cable connector, and pull up to disconnect it from the motherboard.
    • Always pull cables by their connectors and not the wires themselves.
  16. PlayStation 5 Power and Eject Button Board Replacement, Remove the fan: stap 16, afbeelding 1 van 3 PlayStation 5 Power and Eject Button Board Replacement, Remove the fan: stap 16, afbeelding 2 van 3 PlayStation 5 Power and Eject Button Board Replacement, Remove the fan: stap 16, afbeelding 3 van 3
    • Lift the fan up and out of the case to remove it.
  17. PlayStation 5 Power and Eject Button Board Replacement, Remove the SSD cover: stap 17, afbeelding 1 van 1
    • Use a Phillips screwdriver to remove the 17 mm-long SSD cover screw.
  18. PlayStation 5 Power and Eject Button Board Replacement: stap 18, afbeelding 1 van 3 PlayStation 5 Power and Eject Button Board Replacement: stap 18, afbeelding 2 van 3 PlayStation 5 Power and Eject Button Board Replacement: stap 18, afbeelding 3 van 3
    • Use your finger to slide the SSD cover towards the top of the device to unclip it from the case.
    • Remove the SSD cover.
  19. PlayStation 5 Power and Eject Button Board Replacement, Remove the optical drive wire: stap 19, afbeelding 1 van 2 PlayStation 5 Power and Eject Button Board Replacement, Remove the optical drive wire: stap 19, afbeelding 2 van 2
    • Use your fingers to grip the edges of the optical drive cable connector, and pull up to disconnect it from the motherboard.
  20. PlayStation 5 Power and Eject Button Board Replacement: stap 20, afbeelding 1 van 2 PlayStation 5 Power and Eject Button Board Replacement: stap 20, afbeelding 2 van 2
    • Use your fingers to grip the edges of the optical drive cable connector, and pull up to disconnect it from the optical drive.
  21. PlayStation 5 Power and Eject Button Board Replacement, Remove the tamper-evident sticker: stap 21, afbeelding 1 van 3 PlayStation 5 Power and Eject Button Board Replacement, Remove the tamper-evident sticker: stap 21, afbeelding 2 van 3 PlayStation 5 Power and Eject Button Board Replacement, Remove the tamper-evident sticker: stap 21, afbeelding 3 van 3
    Koop
    • Use a pair of tweezers to remove the tamper-evident sticker covering the remaining case screw.
    • If your PlayStation 5 hasn't been opened before, this sticker will be completely black. The pattern will appear after you remove it.
    • Technically, these are tamper-evident stickers—but don't worry—Sony can't legally void your warranty, as long as you don't damage anything. Have fun!
  22. PlayStation 5 Power and Eject Button Board Replacement, Remove the case screws: stap 22, afbeelding 1 van 1
    • Use a T8 Torx driver to remove the eleven screws securing the case:
    • Six 18.6 mm-long screws
    • Two 43.2 mm-long screws
    • One 7.3 mm-long screw
  23. PlayStation 5 Power and Eject Button Board Replacement, Remove the case: stap 23, afbeelding 1 van 2 PlayStation 5 Power and Eject Button Board Replacement, Remove the case: stap 23, afbeelding 2 van 2
    • Lift the case straight up to remove it.
  24. PlayStation 5 Power and Eject Button Board Replacement, Remove the optical drive ribbon cable: stap 24, afbeelding 1 van 3 PlayStation 5 Power and Eject Button Board Replacement, Remove the optical drive ribbon cable: stap 24, afbeelding 2 van 3 PlayStation 5 Power and Eject Button Board Replacement, Remove the optical drive ribbon cable: stap 24, afbeelding 3 van 3
    • Use the flat end of a spudger to press down on the optical drive connector's metal locking tab.
    • With the metal tab depressed, use a pair of tweezers to pull the blue pull tab directly away from the connector to disconnect the cable from the optical drive.
    • Pull only on the pull tab, not the cable itself.
  25. PlayStation 5 Power and Eject Button Board Replacement, Remove the optical drive: stap 25, afbeelding 1 van 2 PlayStation 5 Power and Eject Button Board Replacement, Remove the optical drive: stap 25, afbeelding 2 van 2
    • Lift the optical drive away from the device to remove it.
  26. PlayStation 5 Power and Eject Button Board Replacement, Remove the optical drive ribbon cable: stap 26, afbeelding 1 van 3 PlayStation 5 Power and Eject Button Board Replacement, Remove the optical drive ribbon cable: stap 26, afbeelding 2 van 3 PlayStation 5 Power and Eject Button Board Replacement, Remove the optical drive ribbon cable: stap 26, afbeelding 3 van 3
    Koop
    • With the metal tab depressed, use a pair of tweezers to pull the blue pull tab directly away from the connector to disconnect the cable from the motherboard.
  27. PlayStation 5 Power and Eject Button Board Replacement, Remove the power and eject button ribbon cable: stap 27, afbeelding 1 van 2 PlayStation 5 Power and Eject Button Board Replacement, Remove the power and eject button ribbon cable: stap 27, afbeelding 2 van 2
    • Use a pair of tweezers to pull the blue pull tab directly away from the connector to disconnect the power and eject button ribbon cable.
  28. PlayStation 5 Power and Eject Button Board Replacement, Remove the LED ribbon cable: stap 28, afbeelding 1 van 2 PlayStation 5 Power and Eject Button Board Replacement, Remove the LED ribbon cable: stap 28, afbeelding 2 van 2
    • Use a pair of tweezers to pull the blue pull tab directly away from the connector to disconnect the LED ribbon cable.
  29. PlayStation 5 Power and Eject Button Board Replacement, Remove the antenna wires: stap 29, afbeelding 1 van 3 PlayStation 5 Power and Eject Button Board Replacement, Remove the antenna wires: stap 29, afbeelding 2 van 3 PlayStation 5 Power and Eject Button Board Replacement, Remove the antenna wires: stap 29, afbeelding 3 van 3
    • Use a pair of tweezers to grip the white Wi-Fi antenna wire at its metal base, as close to the connector as possible.
    • Lift the wire's connector straight up to disconnect it from the motherboard.
    • Repeat for the black Wi-Fi antenna wire.
    • Some board revisions may not have these antenna wires. If your board is missing these connectors, skip this step.
  30. PlayStation 5 Power and Eject Button Board Replacement: stap 30, afbeelding 1 van 3 PlayStation 5 Power and Eject Button Board Replacement: stap 30, afbeelding 2 van 3 PlayStation 5 Power and Eject Button Board Replacement: stap 30, afbeelding 3 van 3
    • Use a pair of tweezers to grip the black or blue power supply antenna wire at its metal base, as close to the connector as possible.
    • Repeat for the white power supply antenna wire.
  31. PlayStation 5 Power and Eject Button Board Replacement, Remove the white stickers: stap 31, afbeelding 1 van 3 PlayStation 5 Power and Eject Button Board Replacement, Remove the white stickers: stap 31, afbeelding 2 van 3 PlayStation 5 Power and Eject Button Board Replacement, Remove the white stickers: stap 31, afbeelding 3 van 3
    • Use a pair of tweezers to peel back the white sticker holding the antenna wires to the top shield plate.
    • Remove the antenna wires from underneath the sticker.
    • Press the white sticker back down onto the top shield plate so it can be reused.
  32. PlayStation 5 Power and Eject Button Board Replacement: stap 32, afbeelding 1 van 3 PlayStation 5 Power and Eject Button Board Replacement: stap 32, afbeelding 2 van 3 PlayStation 5 Power and Eject Button Board Replacement: stap 32, afbeelding 3 van 3
    • Repeat the previous step to peel back the four remaining stickers.
  33. PlayStation 5 Power and Eject Button Board Replacement: stap 33, afbeelding 1 van 3 PlayStation 5 Power and Eject Button Board Replacement: stap 33, afbeelding 2 van 3 PlayStation 5 Power and Eject Button Board Replacement: stap 33, afbeelding 3 van 3
    • Use a pair of tweezers to peel back the white sticker holding the LED ribbon cable to the heat sink.
    • Remove the LED ribbon cable from underneath the sticker.
    • Press the white sticker back down onto the heat sink so it can be reused.
  34. PlayStation 5 Power and Eject Button Board Replacement, Remove the top shield plate screws: stap 34, afbeelding 1 van 1
    • Use a T8 Torx driver to remove the forty-two screws securing the top shield plate:
    • Forty-one 7.3 mm-long screws
    • One 43.2 mm-long screw
  35. PlayStation 5 Power and Eject Button Board Replacement, Remove the top shield plate: stap 35, afbeelding 1 van 3 PlayStation 5 Power and Eject Button Board Replacement, Remove the top shield plate: stap 35, afbeelding 2 van 3 PlayStation 5 Power and Eject Button Board Replacement, Remove the top shield plate: stap 35, afbeelding 3 van 3
    • Lift the top shield plate off of the motherboard to remove it.
    • During reassembly, this is a good point to replace any thermal pads on the top of the main board, if necessary. The pads may be stuck to both the top shield plate and the main board.
    • It's important that the replacement pads are the same thickness as the originals, otherwise the foam around the APU may not seal properly.
  36. PlayStation 5 Power and Eject Button Board Replacement, Disconnect the USB board: stap 36, afbeelding 1 van 3 PlayStation 5 Power and Eject Button Board Replacement, Disconnect the USB board: stap 36, afbeelding 2 van 3 PlayStation 5 Power and Eject Button Board Replacement, Disconnect the USB board: stap 36, afbeelding 3 van 3
    • Use your finger to depress the metal locking tab on the USB board cable's board connector.
    • With the metal tab depressed, place the flat end of a spudger against the insulating foam pad on the ribbon cable and pull it directly away from the connector to disconnect it.
  37. PlayStation 5 Power and Eject Button Board Replacement, Remove the left faceplate: stap 37, afbeelding 1 van 3 PlayStation 5 Power and Eject Button Board Replacement, Remove the left faceplate: stap 37, afbeelding 2 van 3 PlayStation 5 Power and Eject Button Board Replacement, Remove the left faceplate: stap 37, afbeelding 3 van 3
    • Lift up the corner of the faceplate with the PlayStation logo to unclip it from the case.
  38. PlayStation 5 Power and Eject Button Board Replacement: stap 38, afbeelding 1 van 2 PlayStation 5 Power and Eject Button Board Replacement: stap 38, afbeelding 2 van 2
    • Remove the left faceplate.
  39. PlayStation 5 Power and Eject Button Board Replacement, Remove the screws: stap 39, afbeelding 1 van 1
    • Use a Torx T8 driver to remove the two 29.4 mm-long screws securing the case to the motherboard and heat sink assembly.
  40. PlayStation 5 Power and Eject Button Board Replacement, Remove the case: stap 40, afbeelding 1 van 3 PlayStation 5 Power and Eject Button Board Replacement, Remove the case: stap 40, afbeelding 2 van 3 PlayStation 5 Power and Eject Button Board Replacement, Remove the case: stap 40, afbeelding 3 van 3
    • Lift the front edge of the case off of the motherboard and heat sink assembly.
    • With the front edge elevated, push the case back, away from the motherboard and heat sink assembly, to maneuver the charging port out of its slot in the case.
    • Remove the case.
    • The front plate may come apart from the plastic case. During reassembly, make sure the front plate is in place before reinserting the motherboard and power supply.
  41. PlayStation 5 Power and Eject Button Board Replacement, Remove the middle panel: stap 41, afbeelding 1 van 2 PlayStation 5 Power and Eject Button Board Replacement, Remove the middle panel: stap 41, afbeelding 2 van 2
    • Lift up to remove the middle panel from the case.
  42. PlayStation 5 Power and Eject Button Board Replacement, Remove the screws: stap 42, afbeelding 1 van 1
    • Use a Phillips screwdriver to remove the two 6.5 mm-long screws securing the power and eject button board to the middle panel.
  43. PlayStation 5 Power and Eject Button Board Replacement, Remove the power and eject button board: stap 43, afbeelding 1 van 2 PlayStation 5 Power and Eject Button Board Replacement, Remove the power and eject button board: stap 43, afbeelding 2 van 2
    Koop
    • Use a pair of tweezers to remove the power and eject button board from the middle panel.
  44. PlayStation 5 Power and Eject Button Board Replacement: stap 44, afbeelding 1 van 2 PlayStation 5 Power and Eject Button Board Replacement: stap 44, afbeelding 2 van 2
Conclusie
Repair didn’t go as planned? Try some basic troubleshooting, or ask our PlayStation 5 Answers community for help.
5 andere personen hebben deze handleiding voltooid.
Robert Boyd
26.668 Reputatie
94 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 29
Afgelopen 30 dagen: 151
Altijd: 5,263
