Ga door naar hoofdinhoud
PlayStation 5 Power Supply Replacement
Wat je nodig hebt
  1. PlayStation 5 Power Supply Replacement, Remove the stand screw: stap 1, afbeelding 1 van 1
    • If your PlayStation 5 is in its vertical orientation, flip it upside down so the stand is facing up.
    • If your PlayStation 5 is in its horizontal orientation, skip to Step 6.
    • Work on a flat surface to prevent your PlayStation from falling over.
    • Use a coin or a flathead screwdriver to remove the 26.5 mm-long stand screw.
  2. PlayStation 5 Power Supply Replacement, Remove the vertical stand: stap 2, afbeelding 1 van 2 PlayStation 5 Power Supply Replacement, Remove the vertical stand: stap 2, afbeelding 2 van 2
    • Lift straight up to remove the stand.
  3. PlayStation 5 Power Supply Replacement, Store the stand screw: stap 3, afbeelding 1 van 2 PlayStation 5 Power Supply Replacement, Store the stand screw: stap 3, afbeelding 2 van 2
    • Insert the screw into the cubby on the bottom of the stand.
  4. PlayStation 5 Power Supply Replacement, Cap the screw hole: stap 4, afbeelding 1 van 3 PlayStation 5 Power Supply Replacement, Cap the screw hole: stap 4, afbeelding 2 van 3 PlayStation 5 Power Supply Replacement, Cap the screw hole: stap 4, afbeelding 3 van 3
    • Use a pair of tweezers or your fingernail to remove the cap from the cubby.
    • Use your finger to press the cap into the screw hole.
  5. PlayStation 5 Power Supply Replacement, Close the cubby: stap 5, afbeelding 1 van 3 PlayStation 5 Power Supply Replacement, Close the cubby: stap 5, afbeelding 2 van 3 PlayStation 5 Power Supply Replacement, Close the cubby: stap 5, afbeelding 3 van 3
    • Twist the stand counterclockwise to close the cubby.
  6. PlayStation 5 Power Supply Replacement, Remove the horizontal stand: stap 6, afbeelding 1 van 2 PlayStation 5 Power Supply Replacement, Remove the horizontal stand: stap 6, afbeelding 2 van 2
    • If your PlayStation 5 is in its horizontal orientation, rest it on its face with the charging port facing up.
    • Lift the stand straight up to remove it.
  7. PlayStation 5 Power Supply Replacement, Remove the right faceplate: stap 7, afbeelding 1 van 3 PlayStation 5 Power Supply Replacement, Remove the right faceplate: stap 7, afbeelding 2 van 3 PlayStation 5 Power Supply Replacement, Remove the right faceplate: stap 7, afbeelding 3 van 3
    • Flip the device over so that the USB and ethernet ports are on the left side from your perspective.
    • Lift up the corner of the faceplate to unclip it from the case.
  8. PlayStation 5 Power Supply Replacement: stap 8, afbeelding 1 van 2 PlayStation 5 Power Supply Replacement: stap 8, afbeelding 2 van 2
    • While lifting up the corner, slide the faceplate towards the bottom of the device.
    • Remove the right faceplate.
  9. PlayStation 5 Power Supply Replacement, Pry up the grille: stap 9, afbeelding 1 van 3 PlayStation 5 Power Supply Replacement, Pry up the grille: stap 9, afbeelding 2 van 3 PlayStation 5 Power Supply Replacement, Pry up the grille: stap 9, afbeelding 3 van 3
    • Insert the flat end of a spudger underneath the grille and into the gap above the fan.
    • Lift up with the spudger to pry the grille away from the case.
  10. PlayStation 5 Power Supply Replacement, Remove the grille: stap 10, afbeelding 1 van 2 PlayStation 5 Power Supply Replacement, Remove the grille: stap 10, afbeelding 2 van 2
    • Lift the grille away from the case to remove it.
    • Use a TR8 Torx security driver to remove the four screws securing the fan shroud to the case:
    • Two 23.3 mm-long screws
    • One 11.4 mm-long screw
    • One 31 mm-long screw
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your console.
  11. PlayStation 5 Power Supply Replacement, Remove the fan shroud: stap 12, afbeelding 1 van 2 PlayStation 5 Power Supply Replacement, Remove the fan shroud: stap 12, afbeelding 2 van 2
    • Lift the fan shroud straight up to remove it.
  12. PlayStation 5 Power Supply Replacement, Remove the wire cover: stap 13, afbeelding 1 van 3 PlayStation 5 Power Supply Replacement, Remove the wire cover: stap 13, afbeelding 2 van 3 PlayStation 5 Power Supply Replacement, Remove the wire cover: stap 13, afbeelding 3 van 3
    • Insert the flat end of a spudger beneath the black wire cover and into the gap above the fan wires.
    • Pry only on the wire cover, not on the fan wires themselves.
    • Use the spudger to peel up the wire cover until you can grip it with your fingers.
  13. PlayStation 5 Power Supply Replacement: stap 14, afbeelding 1 van 3 PlayStation 5 Power Supply Replacement: stap 14, afbeelding 2 van 3 PlayStation 5 Power Supply Replacement: stap 14, afbeelding 3 van 3
    • Use your fingers to peel off the wire cover.
  14. PlayStation 5 Power Supply Replacement, Disconnect the fan: stap 15, afbeelding 1 van 2 PlayStation 5 Power Supply Replacement, Disconnect the fan: stap 15, afbeelding 2 van 2
    • Use your fingers to grip the edges of the fan cable connector, and pull up to disconnect it from the motherboard.
    • Always pull cables by their connectors and not the wires themselves.
  15. PlayStation 5 Power Supply Replacement, Remove the fan: stap 16, afbeelding 1 van 3 PlayStation 5 Power Supply Replacement, Remove the fan: stap 16, afbeelding 2 van 3 PlayStation 5 Power Supply Replacement, Remove the fan: stap 16, afbeelding 3 van 3
    • Lift the fan up and out of the case to remove it.
  16. PlayStation 5 Power Supply Replacement, Remove the SSD cover: stap 17, afbeelding 1 van 1
    • Use a Phillips screwdriver to remove the 17 mm-long SSD cover screw.
  17. PlayStation 5 Power Supply Replacement: stap 18, afbeelding 1 van 3 PlayStation 5 Power Supply Replacement: stap 18, afbeelding 2 van 3 PlayStation 5 Power Supply Replacement: stap 18, afbeelding 3 van 3
    • Use your finger to slide the SSD cover towards the top of the device to unclip it from the case.
    • Remove the SSD cover.
  18. PlayStation 5 Power Supply Replacement, Remove the optical drive wire: stap 19, afbeelding 1 van 2 PlayStation 5 Power Supply Replacement, Remove the optical drive wire: stap 19, afbeelding 2 van 2
    • Use your fingers to grip the edges of the optical drive cable connector, and pull up to disconnect it from the motherboard.
  19. PlayStation 5 Power Supply Replacement: stap 20, afbeelding 1 van 2 PlayStation 5 Power Supply Replacement: stap 20, afbeelding 2 van 2
    • Use your fingers to grip the edges of the optical drive cable connector, and pull up to disconnect it from the optical drive.
  20. PlayStation 5 Power Supply Replacement, Remove the tamper-evident sticker: stap 21, afbeelding 1 van 3 PlayStation 5 Power Supply Replacement, Remove the tamper-evident sticker: stap 21, afbeelding 2 van 3 PlayStation 5 Power Supply Replacement, Remove the tamper-evident sticker: stap 21, afbeelding 3 van 3
    • Use a pair of tweezers to remove the tamper-evident sticker covering the remaining case screw.
    • If your PlayStation 5 hasn't been opened before, this sticker will be completely black. The pattern will appear after you remove it.
    • Technically, these are tamper-evident stickers—but don't worry—Sony can't legally void your warranty, as long as you don't damage anything. Have fun!
  21. PlayStation 5 Power Supply Replacement, Remove the case screws: stap 22, afbeelding 1 van 1
    • Use a T8 Torx driver to remove the eleven screws securing the case:
    • Six 18.6 mm-long screws
    • Two 43.2 mm-long screws
    • One 7.3 mm-long screw
  22. PlayStation 5 Power Supply Replacement, Remove the case: stap 23, afbeelding 1 van 2 PlayStation 5 Power Supply Replacement, Remove the case: stap 23, afbeelding 2 van 2
    • Lift the case straight up to remove it.
  23. PlayStation 5 Power Supply Replacement, Remove the optical drive ribbon cable: stap 24, afbeelding 1 van 3 PlayStation 5 Power Supply Replacement, Remove the optical drive ribbon cable: stap 24, afbeelding 2 van 3 PlayStation 5 Power Supply Replacement, Remove the optical drive ribbon cable: stap 24, afbeelding 3 van 3
    • Use the flat end of a spudger to press down on the optical drive connector's metal locking tab.
    • With the metal tab depressed, use a pair of tweezers to pull the blue pull tab directly away from the connector to disconnect the cable from the optical drive.
    • Pull only on the pull tab, not the cable itself.
  24. PlayStation 5 Power Supply Replacement, Remove the optical drive: stap 25, afbeelding 1 van 2 PlayStation 5 Power Supply Replacement, Remove the optical drive: stap 25, afbeelding 2 van 2
    • Lift the optical drive away from the device to remove it.
  25. PlayStation 5 Power Supply Replacement, Remove the optical drive ribbon cable: stap 26, afbeelding 1 van 3 PlayStation 5 Power Supply Replacement, Remove the optical drive ribbon cable: stap 26, afbeelding 2 van 3 PlayStation 5 Power Supply Replacement, Remove the optical drive ribbon cable: stap 26, afbeelding 3 van 3
    • With the metal tab depressed, use a pair of tweezers to pull the blue pull tab directly away from the connector to disconnect the cable from the motherboard.
  26. PlayStation 5 Power Supply Replacement, Remove the power and eject button ribbon cable: stap 27, afbeelding 1 van 2 PlayStation 5 Power Supply Replacement, Remove the power and eject button ribbon cable: stap 27, afbeelding 2 van 2
    • Use a pair of tweezers to pull the blue pull tab directly away from the connector to disconnect the power and eject button ribbon cable.
  27. PlayStation 5 Power Supply Replacement, Remove the LED ribbon cable: stap 28, afbeelding 1 van 2 PlayStation 5 Power Supply Replacement, Remove the LED ribbon cable: stap 28, afbeelding 2 van 2
    • Use a pair of tweezers to pull the blue pull tab directly away from the connector to disconnect the LED ribbon cable.
  28. PlayStation 5 Power Supply Replacement, Remove the antenna wires: stap 29, afbeelding 1 van 3 PlayStation 5 Power Supply Replacement, Remove the antenna wires: stap 29, afbeelding 2 van 3 PlayStation 5 Power Supply Replacement, Remove the antenna wires: stap 29, afbeelding 3 van 3
    • Use a pair of tweezers to grip the white Wi-Fi antenna wire at its metal base, as close to the connector as possible.
    • Lift the wire's connector straight up to disconnect it from the motherboard.
    • Repeat for the black Wi-Fi antenna wire.
    • Some board revisions may not have these antenna wires. If your board is missing these connectors, skip this step.
  29. PlayStation 5 Power Supply Replacement: stap 30, afbeelding 1 van 3 PlayStation 5 Power Supply Replacement: stap 30, afbeelding 2 van 3 PlayStation 5 Power Supply Replacement: stap 30, afbeelding 3 van 3
    • Use a pair of tweezers to grip the black or blue power supply antenna wire at its metal base, as close to the connector as possible.
    • Repeat for the white power supply antenna wire.
  30. PlayStation 5 Power Supply Replacement, Remove the white stickers: stap 31, afbeelding 1 van 3 PlayStation 5 Power Supply Replacement, Remove the white stickers: stap 31, afbeelding 2 van 3 PlayStation 5 Power Supply Replacement, Remove the white stickers: stap 31, afbeelding 3 van 3
    • Use a pair of tweezers to peel back the white sticker holding the antenna wires to the top shield plate.
    • Remove the antenna wires from underneath the sticker.
    • Press the white sticker back down onto the top shield plate so it can be reused.
  31. PlayStation 5 Power Supply Replacement: stap 32, afbeelding 1 van 3 PlayStation 5 Power Supply Replacement: stap 32, afbeelding 2 van 3 PlayStation 5 Power Supply Replacement: stap 32, afbeelding 3 van 3
    • Repeat the previous step to peel back the four remaining stickers.
  32. PlayStation 5 Power Supply Replacement: stap 33, afbeelding 1 van 3 PlayStation 5 Power Supply Replacement: stap 33, afbeelding 2 van 3 PlayStation 5 Power Supply Replacement: stap 33, afbeelding 3 van 3
    • Use a pair of tweezers to peel back the white sticker holding the LED ribbon cable to the heat sink.
    • Remove the LED ribbon cable from underneath the sticker.
    • Press the white sticker back down onto the heat sink so it can be reused.
  33. PlayStation 5 Power Supply Replacement, Remove the top shield plate screws: stap 34, afbeelding 1 van 1
    • Use a T8 Torx driver to remove the forty-two screws securing the top shield plate:
    • Forty-one 7.3 mm-long screws
    • One 43.2 mm-long screw
  34. PlayStation 5 Power Supply Replacement, Remove the top shield plate: stap 35, afbeelding 1 van 3 PlayStation 5 Power Supply Replacement, Remove the top shield plate: stap 35, afbeelding 2 van 3 PlayStation 5 Power Supply Replacement, Remove the top shield plate: stap 35, afbeelding 3 van 3
    • Lift the top shield plate off of the motherboard to remove it.
  35. PlayStation 5 Power Supply Replacement, Disconnect the USB board: stap 36, afbeelding 1 van 3 PlayStation 5 Power Supply Replacement, Disconnect the USB board: stap 36, afbeelding 2 van 3 PlayStation 5 Power Supply Replacement, Disconnect the USB board: stap 36, afbeelding 3 van 3
    • Use your finger to depress the metal locking tab on the USB board cable's board connector.
    • With the metal tab depressed, place the flat end of a spudger against the insulating foam pad on the ribbon cable and pull it directly away from the connector to disconnect it.
  36. PlayStation 5 Power Supply Replacement, Remove the left faceplate: stap 37, afbeelding 1 van 3 PlayStation 5 Power Supply Replacement, Remove the left faceplate: stap 37, afbeelding 2 van 3 PlayStation 5 Power Supply Replacement, Remove the left faceplate: stap 37, afbeelding 3 van 3
    • Lift up the corner of the faceplate with the PlayStation logo to unclip it from the case.
  37. PlayStation 5 Power Supply Replacement: stap 38, afbeelding 1 van 2 PlayStation 5 Power Supply Replacement: stap 38, afbeelding 2 van 2
    • Remove the left faceplate.
  38. PlayStation 5 Power Supply Replacement, Remove the screws: stap 39, afbeelding 1 van 1
    • Use a Torx T8 driver to remove the two 29.4 mm-long screws securing the case to the motherboard and heat sink assembly.
  39. PlayStation 5 Power Supply Replacement, Remove the case: stap 40, afbeelding 1 van 3 PlayStation 5 Power Supply Replacement, Remove the case: stap 40, afbeelding 2 van 3 PlayStation 5 Power Supply Replacement, Remove the case: stap 40, afbeelding 3 van 3
    • Lift the front edge of the case off of the motherboard and heat sink assembly.
    • With the front edge elevated, push the case back, away from the motherboard and heat sink assembly, to maneuver the charging port out of its slot in the case.
    • Remove the case.
  40. PlayStation 5 Power Supply Replacement, Remove the power supply: stap 41, afbeelding 1 van 2 PlayStation 5 Power Supply Replacement, Remove the power supply: stap 41, afbeelding 2 van 2
    • Use a finger to hold the rear shield plate down against the work surface.
    • Grip the power supply and lift it straight up to disconnect it from the motherboard.
Conclusie
Repair didn’t go as planned? Try some basic troubleshooting, or ask our PlayStation 5 Answers community for help.
19 andere personen hebben deze handleiding voltooid.
Robert Boyd
24.984 Reputatie
94 handleidingen geschreven
14 opmerkingen
Is there any place to buy a replacement power supply?
anon - Antwoord
Where can I get the power supply unit which is Model ADP-400DR ? Please help me
Addis - Antwoord
egamephone have ps5 power supply replacement
kasynlife -
So I started with a dead PS5. I had another power supply laying about but from a different revision. I replaced the power supply with said other power supply that works. When I put it back together still no power. Does each revision used a different power supply or would it be the same?
askanison420 - Antwoord
i’m having the same problem, did you ever get it to work?
abrey -
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 133
Afgelopen 7 dagen: 808
Afgelopen 30 dagen: 3,866
Altijd: 71,964
