Ga door naar hoofdinhoud
Plastic Tooth Zipper Slider Replacement
Wat je nodig hebt
  1. Plastic Tooth Zipper Slider Replacement, Gather materials: stap 1, afbeelding 1 van 3 Plastic Tooth Zipper Slider Replacement, Gather materials: stap 1, afbeelding 2 van 3 Plastic Tooth Zipper Slider Replacement, Gather materials: stap 1, afbeelding 3 van 3
    • Gather tools and the two pieces required for a plastic tooth slider replacement:
    • A replacement slider that is the right size and style
    • Reference the Zipper Identification guide to confirm the appropriate replacement piece.
    • A top stop
    • There are two types of metal top stops, both of which can be used on plastic tooth zippers (reference image #3).
  2. Plastic Tooth Zipper Slider Replacement, Locate the top stop: stap 2, afbeelding 1 van 3 Plastic Tooth Zipper Slider Replacement, Locate the top stop: stap 2, afbeelding 2 van 3 Plastic Tooth Zipper Slider Replacement, Locate the top stop: stap 2, afbeelding 3 van 3
    • Unzip the zipper.
    • Locate the top stop at the top of the zipper on the side with the slider.
    • The top stop is a piece of plastic or metal that keeps the slider from coming off the top of the zipper.
  3. Plastic Tooth Zipper Slider Replacement, Remove the top stop: stap 3, afbeelding 1 van 3 Plastic Tooth Zipper Slider Replacement, Remove the top stop: stap 3, afbeelding 2 van 3 Plastic Tooth Zipper Slider Replacement, Remove the top stop: stap 3, afbeelding 3 van 3
    • Wear safety glasses to protect from projectile pieces.
    • Use end nippers or flush cutters to remove the top stop.
    • To avoid cutting the zipper tape, position the nippers to cut off only the very edge of the stop.
  4. Plastic Tooth Zipper Slider Replacement: stap 4, afbeelding 1 van 3 Plastic Tooth Zipper Slider Replacement: stap 4, afbeelding 2 van 3 Plastic Tooth Zipper Slider Replacement: stap 4, afbeelding 3 van 3
    • Peel away the rest of the top stop from the zipper tape.
    • Use a lighter to lightly singe any fraying zipper tape.
  5. Plastic Tooth Zipper Slider Replacement, Remove the damaged slider: stap 5, afbeelding 1 van 3 Plastic Tooth Zipper Slider Replacement, Remove the damaged slider: stap 5, afbeelding 2 van 3 Plastic Tooth Zipper Slider Replacement, Remove the damaged slider: stap 5, afbeelding 3 van 3
    • Slide the damaged zipper slider up and off the zipper tape.
    • Discard the zipper slider responsibly.
  6. Plastic Tooth Zipper Slider Replacement, Attach the new slider: stap 6, afbeelding 1 van 3 Plastic Tooth Zipper Slider Replacement, Attach the new slider: stap 6, afbeelding 2 van 3 Plastic Tooth Zipper Slider Replacement, Attach the new slider: stap 6, afbeelding 3 van 3
    • Making sure the new slider is oriented correctly, slide it onto the zipper tape.
    • Patagonia Repair Tech Tip: Maneuver the slider as if parallel parking a car. Start at an angle, back it onto the zipper tape, and then straighten out. This step can take practice, patience, and a little muscle!
    • Once the slider is on the zipper, test zipping up the jacket to make sure it's the right slider type and that the issue is fixed.
  7. Plastic Tooth Zipper Slider Replacement, Place the new top stop: stap 7, afbeelding 1 van 3 Plastic Tooth Zipper Slider Replacement, Place the new top stop: stap 7, afbeelding 2 van 3 Plastic Tooth Zipper Slider Replacement, Place the new top stop: stap 7, afbeelding 3 van 3
    • Grab a replacement top stop and position it around the edge of the zipper tape directly above the top teeth, where the old stop was located.
  8. Plastic Tooth Zipper Slider Replacement, Attach the new top stop: stap 8, afbeelding 1 van 3 Plastic Tooth Zipper Slider Replacement, Attach the new top stop: stap 8, afbeelding 2 van 3 Plastic Tooth Zipper Slider Replacement, Attach the new top stop: stap 8, afbeelding 3 van 3
    • Use pliers to crimp the top stop into place.
    • Check that the new stop effectively prevents the new slider from coming off the zipper.
Eindstreep
61 andere personen hebben deze handleiding voltooid.
Brittany McCrigler
89.868 Reputatie
142 handleidingen geschreven
iFixit Lid van iFixit
Staff
118 Leden
19.648 handleidingen geschreven
23Gids Commentaar
Where do I get the parts needed?
jonaskrat - Antwoord
Off of another zipper
nerdyrepair -
Amazon has replacement parts, but I found you can get almost any zipper parts from a sailing supply company called sailrite.com.
Scott Lamorte -
Perfect...thank you! I had seen about 10 other videos on how to do this repair but yours was the one that showed me exactly how to do it and it worked perfectly the first time. Much appreciated!
starrdustt57 - Antwoord
Thank you! This was great - I ordered the knippers and replacement parts for a jacket of mine that I broke, as I know my children will be breaking there's sooner or later. It cost me $10 instead of $40+ to replace a jacket.
Megan Elmore - Antwoord
Where did you get the replacement end plastic endstop?
Deborah Spaulding -
I can not thank you enough for this tutorial. I had contacted a seamstress and she said it would have to be replaced. Thank heavens I found your site. The zipper pull has been replaced on the zipper and I'm awaiting my order of stops to replace the top stop. Thank you, Thank you!
Mary Axtell - Antwoord
Where can I buy the things needed to do this please?
Val Neale - Antwoord
Amazon or sailrite.com
Scott Lamorte -
Hi
The tutorial is fab and I checked out sailrite for zippers which brings me a step further, but how do I determine the right size zipper. There is no numbers or anything on my current broken zipper. I thought about measuring the bottom or the top and going from that measurement? Any feedback appreciated.
thanks Jenny
Jenny - Antwoord
Where did you get the replacement stop?
edward schmitt - Antwoord
I lost the original slider …. how will we know what to buy ?
Rishi Rampaul - Antwoord
I lost the original slider … how will I know what to buy ?
Sometimes, if the slider is not broken, but it doen’t connect the two sides any more, you can very, very gently squize the upper and lower side of the slider. Most of the times it will be o.k. again.
Paul A. - Antwoord
You can check other zippers (if any) on pockets as they’re often the same size. A good quality zipper will have the size stamped on the back. Standard exterior coat zippers are size 5.
Sarah Gerber - Antwoord
Thanks for keeping this tutorial up! I broke a tooth near the bottom stopper on a zipper and this helped me to fashion a fix!
Jamie Saulsbury - Antwoord
'''Plastic zipper on a comforter coverlet will not stay zipped… it splits on both sides of the zipper. There’s no # on bottom of slider(made in China I think!) so how do I fix it? It’s a small slider.. nothing actually seems to be wrong with the slider! The plastic zipper just won’t start… it gaps open every time you zip it! In front & in back of the slider!!
Marcia - Antwoord
How can I fix one with the slider (plastic teeth) when the stop is hidden (Sewn in) And I managed to get both sides feeding into the slider just fine but when I zip it, the zipper behind just pulls apart again. (This is on a Large sectional-sized throw pillow) so… it’s on track on both sides, the slider moves, but the zipper won’t stay zipped. It just pulls agape again. Help please
garnetthudnall - Antwoord
Thanks so much! Zipper fixed in a few minutes :) I just reused the stopper piece too :) Great presentation with excellent video quality =D Thank you ☺️
Lesley Pain - Antwoord
To determine what type and size of slider you might need, please check out this guide below. Video: Introduction to Zipper Types and Slider Identification
Once you know which type and size you need contact Patagonia Customer Service ( 1-800-638-6464) for a new Slider and Zipper Stop. Please have your type and size available to provide to the CS Agent.
Tools for the job were listed above in the "Tools" section, if you place your cursor over the link a little window will pop up. If you click on it it will take you to a vendor to purchase any tool that needed.
Good Luck.
Marty Chapman - Antwoord
If your garments were made better the zippers wouldn't break so often. I've had three SST jackets and various zippers have failed on all three. Now I but Rapala Pro jackets - twice the jacket at half the price.
Garnet Brake - Antwoord
How do I replace jusy 1 tooth toward the middle?
Silky Jones - Antwoord
Thank You ! Very Helpful ! Yay!
PL Low - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 79
Afgelopen 7 dagen: 478
Afgelopen 30 dagen: 2,210
Altijd: 777,770
