Ga door naar hoofdinhoud
Photive Rain Battery Replacement
Wat je nodig hebt
    1. Photive Rain Battery Replacement, Back Panel: stap 1, afbeelding 1 van 1
      • Turn the speaker off before disassembling.
      • Remove the suction cup from its groove by twisting and turning it.
      Vraag FixBot
      Voeg opmerking toe
    2. Photive Rain Battery Replacement: stap 2, afbeelding 1 van 1
      • Remove the four 8.5 mm screws from the back panel of the speaker by using the Phillips #1 Screwdriver.
      • Remove back panel
      Vraag FixBot
      Voeg opmerking toe
    1. Photive Rain Battery Replacement, Battery: stap 3, afbeelding 1 van 2 Photive Rain Battery Replacement, Battery: stap 3, afbeelding 2 van 2
      • Remove the plastic cover in front of the battery slot.
      • Unscrew all the 8.5mm screws that hold the cover to the slot.
      • Separate the battery from the back panel as shown in photograph 3.
      • Caution: manipulation of the device while the battery is still connected to the motherboard may result in electric shock.
      Vraag FixBot
      Voeg opmerking toe
    2. Photive Rain Battery Replacement: stap 4, afbeelding 1 van 1
      • Remove the battery from the motherboard.
      • Use a soldering pen to remove the solder connecting the battery wires to the motherboard.
      • Click here to access the iFixit Soldering Guide. This will provide a safe and instructive manual on the usage of soldering pens.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
abcdef ghijk
723 Reputatie
4 handleidingen geschreven
IUPUI, Team 1-4, Harley Spring 2016 Lid van IUPUI, Team 1-4, Harley Spring 2016
IUPUI-HARLEY-S16S1G4
3 Leden
8 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 29
Altijd: 821
