Ga door naar hoofdinhoud
Philips Sonicare FlexCare Battery Replacement
Wat je nodig hebt
  1. Philips Sonicare FlexCare Battery Replacement, Battery: stap 1, afbeelding 1 van 1
    • Pull the brush head away from the handle to remove it.
  2. Philips Sonicare FlexCare Battery Replacement: stap 2, afbeelding 1 van 1
    • Push the flat edge of a metal or nylon spudger between the seal and the toothbrush body and pry it open. Do this all around the edge until the seal is partially sticking out.
    • Have a look to an alternative opening procedure.
  3. Philips Sonicare FlexCare Battery Replacement: stap 3, afbeelding 1 van 1
    • Apply pressure to the shaft by pressing it against a firm and flat surface. Continue to apply pressure until the electronics located in the interior are exposed.
  4. Philips Sonicare FlexCare Battery Replacement: stap 4, afbeelding 1 van 1
    • Grab the circular, plastic base with the o-ring and pull it outward.
  5. Philips Sonicare FlexCare Battery Replacement: stap 5, afbeelding 1 van 1
    • Remove the cap that is attached to the end of the interior by removing the two clasps that are holding it in place.
  6. Philips Sonicare FlexCare Battery Replacement: stap 6, afbeelding 1 van 1
    • Desolder the battery from the circuit board. Here is a guide on how to desolder. Remove the old battery and replace it. Using the same guide, solder the battery in place.
    • The soldering points are shown in red.
Conclusie
37 andere personen hebben deze handleiding voltooid.
Joanna Moraza
1.623 Reputatie
2 handleidingen geschreven
Cal Poly, Team 4-6, Maness Spring 2015 Lid van Cal Poly, Team 4-6, Maness Spring 2015
CPSU-MANESS-S15S4G6
4 Leden
23 handleidingen geschreven
36 opmerkingen
has anyone ever done this successfully? OMG it seems daunting!!!!
Jo - Antwoord
I'm going to try it. Now, to find a battery source.
Scott Minton - Antwoord
Anyone knows where to purchase such battery and its type/sort code?
Ben Salem - Antwoord
The battery is a 14500 li-ion with soldered pins.
I bought this one without pin and will try to solder them:
http://www.ebay.de/itm/371716530024
Here, you can buy the version with pins:
https://www.amazon.com/Battery-Sonicare-...
mamuc -
Prying open the bottom of the brush like that can damage the plastic. There's a damage-free technique detailed on this guide:
http://toothbrushbattery.com/guides/phil...
Dave W - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 123
Afgelopen 7 dagen: 741
Afgelopen 30 dagen: 3,592
Altijd: 296,387
