Ga door naar hoofdinhoud
Panasonic KX-TGE233 Power Port Replacement
Wat je nodig hebt
  1. Panasonic KX-TGE233 Power Port Replacement, Base Front Panel Assembly: stap 1, afbeelding 1 van 1
    • To fix this component, we'll need to work with the main docking station. This is the one with the answering machine and the TEL line.
  2. Panasonic KX-TGE233 Power Port Replacement: stap 2, afbeelding 1 van 1
    • To start, we'll need to work with objects on the bottom of the device, so begin by flipping the device over.
  3. Panasonic KX-TGE233 Power Port Replacement: stap 3, afbeelding 1 van 1
    • To open the main docking station, you'll need to remove four 11 mm Philips #0 screws.
  4. Panasonic KX-TGE233 Power Port Replacement: stap 4, afbeelding 1 van 1
    • With the screws removed, you can use a spudger to aid in removing the back from the device.
    • Levering the back by the spudger may break the tool!
  5. Panasonic KX-TGE233 Power Port Replacement: stap 5, afbeelding 1 van 1
    • With the back removed, we now have direct access to all other components in the main docking station.
  6. Panasonic KX-TGE233 Power Port Replacement, Power Port: stap 6, afbeelding 1 van 1
    • Now that the device has been opened, the power port can easily be removed from its resting point.
  7. Panasonic KX-TGE233 Power Port Replacement: stap 7, afbeelding 1 van 1
  8. Panasonic KX-TGE233 Power Port Replacement: stap 8, afbeelding 1 van 1
    • The faulty power port can now be detached from the device from its contact points. If soldering has been successful, removal should require minimal effort.
Conclusie
Nico Cruz
249 Reputatie
2 handleidingen geschreven
IUPUI, Team 2-2, Baechle Spring 2016 Lid van IUPUI, Team 2-2, Baechle Spring 2016
IUPUI-BAECHLE-S16S2G2
5 Leden
15 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 30
Altijd: 2,616
