Ga door naar hoofdinhoud
Panasonic KX-TGE233 Back Speaker Replacement
Wat je nodig hebt
  1. Panasonic KX-TGE233 Back Speaker Replacement, Battery: stap 1, afbeelding 1 van 2 Panasonic KX-TGE233 Back Speaker Replacement, Battery: stap 1, afbeelding 2 van 2
    • Flip the handset over to expose the back panel, and slide the panel out to remove.
  2. Panasonic KX-TGE233 Back Speaker Replacement: stap 2, afbeelding 1 van 1
    • Carefully remove the two batteries by lifting up from one end.
  3. Panasonic KX-TGE233 Back Speaker Replacement, Handset Front Panel Assembly: stap 3, afbeelding 1 van 1
    • Remove the two screws behind the battery panel by using a Philips size #00 screwdriver.
  4. Panasonic KX-TGE233 Back Speaker Replacement: stap 4, afbeelding 1 van 1
    • Using a spudger, open the device by starting from the bottom and working your way to the top.
    • This will require some force, so be careful not to break any of the wires inside of the device.
  5. Panasonic KX-TGE233 Back Speaker Replacement: stap 5, afbeelding 1 van 1
    • Once the back has been separated from the rest of the device, carefully place it to the side. Be careful not to completely remove it, however, as there are wires connecting the back to the handset.
  6. Panasonic KX-TGE233 Back Speaker Replacement: stap 6, afbeelding 1 van 1
    • Using the same screwdriver as before, remove the Philips size #00 screw holding the motherboard in place.
  7. Panasonic KX-TGE233 Back Speaker Replacement: stap 7, afbeelding 1 van 1
    • With the screw removed, the front panel assembly can be separated from the rest of the device.
  8. Panasonic KX-TGE233 Back Speaker Replacement, Back Speaker: stap 8, afbeelding 1 van 1
    • Detach the piece from the back panel. It should already be separate at this point, but it is important to ensure that it is since we'll be working exclusively with the back in this guide.
  9. Panasonic KX-TGE233 Back Speaker Replacement: stap 9, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    • The back speaker is held in with a metal frame. To remove it, push the handles of the frame together with tweezers and lift. The speaker can now be easily taken out.
  10. Panasonic KX-TGE233 Back Speaker Replacement: stap 10, afbeelding 1 van 1
  11. Panasonic KX-TGE233 Back Speaker Replacement: stap 11, afbeelding 1 van 1
    • You can now remove the speaker from its contact points. This should require minimal effort if you have completed the soldering step properly.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Jesse Satterwhite
682 Reputatie
5 handleidingen geschreven
IUPUI, Team 2-2, Baechle Spring 2016 Lid van IUPUI, Team 2-2, Baechle Spring 2016
IUPUI-BAECHLE-S16S2G2
5 Leden
15 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 17
Afgelopen 30 dagen: 49
Altijd: 913
