Ga door naar hoofdinhoud
Palm TX Power Button Replacement
Wat je nodig hebt
    1. Palm TX Power Button Replacement, Back Panel: stap 1, afbeelding 1 van 2 Palm TX Power Button Replacement, Back Panel: stap 1, afbeelding 2 van 2
      • Orient the device so that the display faces forward.
      • Remove the stylus from the right side.
      Vraag FixBot
      Voeg opmerking toe
    2. Palm TX Power Button Replacement: stap 2, afbeelding 1 van 1
      • Turn over the device so that the back panel faces forward.
      • Use a T5 Torx screwdriver to remove the four 6.35mm corner screws.
      Vraag FixBot
      Voeg opmerking toe
    3. Palm TX Power Button Replacement: stap 3, afbeelding 1 van 2 Palm TX Power Button Replacement: stap 3, afbeelding 2 van 2
      • Rotate the device so that the display faces forward.
      • Insert a plastic opening tool with the angled tip pointing downward into the crevice on the left side of the device.
      • Pry along the crevice to loosen the back panel.
      • Repeat this process for the right side.
      Vraag FixBot
      Voeg opmerking toe
    4. Palm TX Power Button Replacement: stap 4, afbeelding 1 van 2 Palm TX Power Button Replacement: stap 4, afbeelding 2 van 2
      • Carefully pry the back panel to open the device.
      • Be careful not to break the wire that connects the battery pack to the motherboard.
      • When reassembling, snap the back panel back into place and then insert the top cover.
      Vraag FixBot
      Voeg opmerking toe
    5. Palm TX Power Button Replacement: stap 5, afbeelding 1 van 2 Palm TX Power Button Replacement: stap 5, afbeelding 2 van 2
      • Use a plastic opening tool to peel the battery pack from the back panel.
      • The battery pack is glued to the back panel so removing it may require considerable effort.
      Vraag FixBot
      Voeg opmerking toe
    1. Palm TX Power Button Replacement, Battery Pack: stap 6, afbeelding 1 van 2 Palm TX Power Button Replacement, Battery Pack: stap 6, afbeelding 2 van 2
      • Use a soldering iron to disconnect the battery wires from the motherboard.
      • For soldering instructions, you can view the Soldering Guide.
      Vraag FixBot
      Voeg opmerking toe
    1. Palm TX Power Button Replacement, Motherboard: stap 7, afbeelding 1 van 2 Palm TX Power Button Replacement, Motherboard: stap 7, afbeelding 2 van 2
      • Pull straight up on the ribbon cables located on the bottom right of the motherboard to disconnect them.
      Vraag FixBot
      Voeg opmerking toe
    2. Palm TX Power Button Replacement: stap 8, afbeelding 1 van 2 Palm TX Power Button Replacement: stap 8, afbeelding 2 van 2
      • Lift the mother board out of the device.
      • A weak adhesive attaches the motherboard to the device.
      • The red wire in the picture will not be attached to your device at this point.
      Vraag FixBot
      Voeg opmerking toe
    1. Palm TX Power Button Replacement, Power Button: stap 9, afbeelding 1 van 1
      • Flip the motherboard so that the black rubber cover faces upward. The power switch is in the top right corner.
      • Remove the button with a soldering iron.
      • For soldering instructions, view the Soldering Guide.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Spencer Lewson
793 Reputatie
6 handleidingen geschreven
Cal Poly, Team 1-15, Amido Winter 2011 Lid van Cal Poly, Team 1-15, Amido Winter 2011
CPSU-AMIDO-W11S1G15
4 Leden
35 handleidingen geschreven
2Gids Commentaar
what do i do after i remove said button?
Dewm - Antwoord Deel
what do i do aftert i desolder the button
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 12
Afgelopen 30 dagen: 46
Altijd: 3,878
