Ga door naar hoofdinhoud
Palm TX Battery Pack Replacement
Wat je nodig hebt
  1. Palm TX Battery Pack Replacement, Back Panel: stap 1, afbeelding 1 van 2 Palm TX Battery Pack Replacement, Back Panel: stap 1, afbeelding 2 van 2
    • Orient the device so that the display faces forward.
    • Remove the stylus from the right side.
    Vraag FixBot
    Voeg opmerking toe
  2. Palm TX Battery Pack Replacement: stap 2, afbeelding 1 van 1
    • Turn over the device so that the back panel faces forward.
    • Use a T5 Torx screwdriver to remove the four 6.35mm corner screws.
    Vraag FixBot
    Voeg opmerking toe
  3. Palm TX Battery Pack Replacement: stap 3, afbeelding 1 van 2 Palm TX Battery Pack Replacement: stap 3, afbeelding 2 van 2
    • Rotate the device so that the display faces forward.
    • Insert a plastic opening tool with the angled tip pointing downward into the crevice on the left side of the device.
    • Pry along the crevice to loosen the back panel.
    • Repeat this process for the right side.
    Vraag FixBot
    Voeg opmerking toe
  4. Palm TX Battery Pack Replacement: stap 4, afbeelding 1 van 2 Palm TX Battery Pack Replacement: stap 4, afbeelding 2 van 2
    • Carefully pry the back panel to open the device.
    • Be careful not to break the wire that connects the battery pack to the motherboard.
    • When reassembling, snap the back panel back into place and then insert the top cover.
    Vraag FixBot
    Voeg opmerking toe
  5. Palm TX Battery Pack Replacement: stap 5, afbeelding 1 van 2 Palm TX Battery Pack Replacement: stap 5, afbeelding 2 van 2
    • Use a plastic opening tool to peel the battery pack from the back panel.
    • The battery pack is glued to the back panel so removing it may require considerable effort.
    Vraag FixBot
    Voeg opmerking toe
  6. Palm TX Battery Pack Replacement, Battery Pack: stap 6, afbeelding 1 van 2 Palm TX Battery Pack Replacement, Battery Pack: stap 6, afbeelding 2 van 2
    • Use a soldering iron to disconnect the battery wires from the motherboard.
    • For soldering instructions, you can view the Soldering Guide.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
5 andere personen hebben deze handleiding voltooid.
Spencer Lewson
793 Reputatie
6 handleidingen geschreven
Cal Poly, Team 1-15, Amido Winter 2011 Lid van Cal Poly, Team 1-15, Amido Winter 2011
CPSU-AMIDO-W11S1G15
4 Leden
16 handleidingen geschreven
1Gids Commentaar
In step 1 - Also remove the cover hinge by sliding downwards
In step 3 - there are actually 2 crevices on the left side of the device. Use the larger, which originally held the cover hinge (the smaller crevice seems to remove the facia)
Jack - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 7
Afgelopen 7 dagen: 18
Afgelopen 30 dagen: 68
Altijd: 8,537
