Ga door naar hoofdinhoud
PDP Rematch Top Left and Right Button(s) Replacement
Wat je nodig hebt
  1. PDP Rematch Top Left and Right Button(s) Replacement, Faceplate: stap 1, afbeelding 1 van 2 PDP Rematch Top Left and Right Button(s) Replacement, Faceplate: stap 1, afbeelding 2 van 2
    • Grip one side of the controller firmly.
    • Insert an opening pick into the crease between the faceplate and the body of the controller.
    • Once the pick creates a gap in the crease, gently insert another pick into a different section of the crease.
    • Carefully move the picks along the controller's crease line until you hear a popping sound.
    • Gently lift off the faceplate by hand.
    Vraag FixBot
    Voeg opmerking toe
  2. PDP Rematch Top Left and Right Button(s) Replacement: stap 2, afbeelding 1 van 2 PDP Rematch Top Left and Right Button(s) Replacement: stap 2, afbeelding 2 van 2
    • Remove the 8 mm screws from the hard cover using a JIS #00 screwdriver.
    • Since the screws have been removed, avoid shaking or moving your controller too much to prevent other buttons from falling out.
    Vraag FixBot
    Voeg opmerking toe
  3. PDP Rematch Top Left and Right Button(s) Replacement: stap 3, afbeelding 1 van 2 PDP Rematch Top Left and Right Button(s) Replacement: stap 3, afbeelding 2 van 2
    • Gently lift off the hard cover with your hand; it should not need much force.
    Vraag FixBot
    Voeg opmerking toe
  4. PDP Rematch Top Left and Right Button(s) Replacement, Top Left and Right Buttons: stap 4, afbeelding 1 van 2 PDP Rematch Top Left and Right Button(s) Replacement, Top Left and Right Buttons: stap 4, afbeelding 2 van 2
    • Remove the back panel by pulling it away from the front.
    • Disconnect the cable by squeezing the two sides while pulling the cable away from the motherboard.
    Vraag FixBot
    Voeg opmerking toe
  5. PDP Rematch Top Left and Right Button(s) Replacement: stap 5, afbeelding 1 van 2 PDP Rematch Top Left and Right Button(s) Replacement: stap 5, afbeelding 2 van 2
    • Touch the hot tip of the soldering iron to the first solder connecting the buttons to the motherboard until the solder melts.
    • Repeat this for the next solder. Verify solders have detached from motherboard.
    • Be careful of the hot soldering tip.
    Vraag FixBot
    Voeg opmerking toe
  6. PDP Rematch Top Left and Right Button(s) Replacement: stap 6, afbeelding 1 van 2 PDP Rematch Top Left and Right Button(s) Replacement: stap 6, afbeelding 2 van 2
    • When the solder has completely melted, flip the controller and gently pull the wire free from the motherboard.
    • Repeat for the other black wire.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
GraceGrubbs
147 Reputatie
1 Handleiding geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 23
Altijd: 531
