Ga door naar hoofdinhoud
Orbo Jr. Motherboard Replacement
Wat je nodig hebt
    1. Orbo Jr. Motherboard Replacement, Battery: stap 1, afbeelding 1 van 1
      • Use your thumbs to gently pry the silicon case away from the tablet starting at one of the corners. Once the first corner is separated the other three corners should slip off easily.
      Vraag FixBot
      Voeg opmerking toe
    2. Orbo Jr. Motherboard Replacement: stap 2, afbeelding 1 van 3 Orbo Jr. Motherboard Replacement: stap 2, afbeelding 2 van 3 Orbo Jr. Motherboard Replacement: stap 2, afbeelding 3 van 3
      • Use the plastic opening tool to pry the back off the tablet. Work your way around the edges. Once you have one side open you can slowly unsnap the rest of the case and use the tool as needed.
      • Go slowly when you pry the back off to ensure you do not crack the case or damage the screen.
      Vraag FixBot
      Voeg opmerking toe
    3. Orbo Jr. Motherboard Replacement: stap 3, afbeelding 1 van 1
      • Gently pull the cables attached to the speaker to remove it from the back cover.
      • The speaker is taped in the back cover and caution should be used when pulling on the wires.
      Vraag FixBot
      Voeg opmerking toe
    4. Orbo Jr. Motherboard Replacement: stap 4, afbeelding 1 van 1
      • Pull back the tape to expose the wires that are attached to the battery.
      Vraag FixBot
      Voeg opmerking toe
    5. Orbo Jr. Motherboard Replacement: stap 5, afbeelding 1 van 2 Orbo Jr. Motherboard Replacement: stap 5, afbeelding 2 van 2
      • Do not attempt to fully remove the battery. It is still connected to the motherboard by two wires.
      • Use a nylon spudger to lift the battery from the right side of the device. Slowly remove the adhesive below the battery.
      • To avoid damage to device and battery, do not attempt to remove the battery until adhesive is completely detached.
      Vraag FixBot
      Voeg opmerking toe
    6. Orbo Jr. Motherboard Replacement: stap 6, afbeelding 1 van 3 Orbo Jr. Motherboard Replacement: stap 6, afbeelding 2 van 3 Orbo Jr. Motherboard Replacement: stap 6, afbeelding 3 van 3
      • Desolder the battery wires from the positive and negative connection to the motherboard. Check out iFixit's How to Solder and Desolder Connections guide for soldering help.
      • Positive and Negative battery terminals.
      • Be careful to not make contact to other components on the motherboard while using the soldering iron.
      Vraag FixBot
      Voeg opmerking toe
    1. Orbo Jr. Motherboard Replacement, Speaker: stap 7, afbeelding 1 van 3 Orbo Jr. Motherboard Replacement, Speaker: stap 7, afbeelding 2 van 3 Orbo Jr. Motherboard Replacement, Speaker: stap 7, afbeelding 3 van 3
      • Unsolder the positive and negative speaker wires from the connection on the motherboard.
      • Be careful to not make contact to other components on the motherboard while using the solder iron.
      Vraag FixBot
      Voeg opmerking toe
    1. Orbo Jr. Motherboard Replacement, Camera: stap 8, afbeelding 1 van 3 Orbo Jr. Motherboard Replacement, Camera: stap 8, afbeelding 2 van 3 Orbo Jr. Motherboard Replacement, Camera: stap 8, afbeelding 3 van 3
      • Use the pointed end of a spudger to flip up the black tab connecting the camera's ribbon cable to the motherboard.
      • Camera ribbon clip.
      • Pull lightly on the ribbon to remove the camera ribbon from the tab.
      Vraag FixBot
      Voeg opmerking toe
    1. Orbo Jr. Motherboard Replacement, Motherboard: stap 9, afbeelding 1 van 3 Orbo Jr. Motherboard Replacement, Motherboard: stap 9, afbeelding 2 van 3 Orbo Jr. Motherboard Replacement, Motherboard: stap 9, afbeelding 3 van 3
      • Unsolder the Wifi wire from the connection on the motherboard.
      • WiFi terminal
      Vraag FixBot
      Voeg opmerking toe
    2. Orbo Jr. Motherboard Replacement: stap 10, afbeelding 1 van 3 Orbo Jr. Motherboard Replacement: stap 10, afbeelding 2 van 3 Orbo Jr. Motherboard Replacement: stap 10, afbeelding 3 van 3
      • Unsolder the display wires from the connection on the motherboard.
      • Display wires
      Vraag FixBot
      Voeg opmerking toe
    3. Orbo Jr. Motherboard Replacement: stap 11, afbeelding 1 van 1
      • Use the flat end of the spudger to lift and remove the black tape covering the ribbon connection tab.
      • The tape should be removed slowly.
      Vraag FixBot
      Voeg opmerking toe
    4. Orbo Jr. Motherboard Replacement: stap 12, afbeelding 1 van 3 Orbo Jr. Motherboard Replacement: stap 12, afbeelding 2 van 3 Orbo Jr. Motherboard Replacement: stap 12, afbeelding 3 van 3
      • Using the tip end of the spudger, slide back the black clips on the side of the right ribbon connection.
      • Gently pull the display ribbons to remove them from the motherboard connections.
      • Repeat the same steps for the left ribbon connection.
      Vraag FixBot
      Voeg opmerking toe
    5. Orbo Jr. Motherboard Replacement: stap 13, afbeelding 1 van 3 Orbo Jr. Motherboard Replacement: stap 13, afbeelding 2 van 3 Orbo Jr. Motherboard Replacement: stap 13, afbeelding 3 van 3
      • Remove the following Phillips #000 screws securing the motherboard.
      • Three 3.0 mm screws
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Ryan Christman
684 Reputatie
5 handleidingen geschreven
USF Tampa, Team 3-1, Sullivan Spring 2016 Lid van USF Tampa, Team 3-1, Sullivan Spring 2016
USFT-SULLIVAN-S16S3G1
4 Leden
10 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 35
Altijd: 710
