Ga door naar hoofdinhoud
Oontz Angle 3 ULTRA Battery Replacement
Wat je nodig hebt
  1. Oontz Angle 3 ULTRA  Battery Replacement, Back Panel: stap 1, afbeelding 1 van 3 Oontz Angle 3 ULTRA  Battery Replacement, Back Panel: stap 1, afbeelding 2 van 3 Oontz Angle 3 ULTRA  Battery Replacement, Back Panel: stap 1, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    • Remove the two black rubber sheaths around the edges of the speaker.
    • Under the symbol-marked sheath there is a white rubber covering for the buttons. Peel this away to reveal the panel underneath.
    • On two corners of its triangular face there is a small divot, which allows you to use your fingernails or a pair of tweezers to grip and peel away the covering.
  2. Oontz Angle 3 ULTRA  Battery Replacement: stap 2, afbeelding 1 van 3 Oontz Angle 3 ULTRA  Battery Replacement: stap 2, afbeelding 2 van 3 Oontz Angle 3 ULTRA  Battery Replacement: stap 2, afbeelding 3 van 3
    • Use a JIS #0 screwdriver to remove the six screws to expose the motherboard.
  3. Oontz Angle 3 ULTRA  Battery Replacement: stap 3, afbeelding 1 van 3 Oontz Angle 3 ULTRA  Battery Replacement: stap 3, afbeelding 2 van 3 Oontz Angle 3 ULTRA  Battery Replacement: stap 3, afbeelding 3 van 3
    • Using a pair of tweezers, pinch and pull the rubber fillings obstructing the screws.
  4. Oontz Angle 3 ULTRA  Battery Replacement: stap 4, afbeelding 1 van 3 Oontz Angle 3 ULTRA  Battery Replacement: stap 4, afbeelding 2 van 3 Oontz Angle 3 ULTRA  Battery Replacement: stap 4, afbeelding 3 van 3
    • Using a JIS #0 screwdriver, remove the 6 screws holding the backplate in.
    • Remove the back panel off of the device.
    Where can I get the mother board and other parts to buy for the Oontz angel 3 please
    Christopher Dunkley - Antwoord
  5. Oontz Angle 3 ULTRA  Battery Replacement, Battery: stap 5, afbeelding 1 van 1
    • Make sure that the device is OFF before operating here, as an electrical spark may occur if the device is operating.
    • Once the motherboard is exposed after disassembly, follow the thick black and red cords from the battery pack to their attachments to the board.
    • Use the soldering iron to melt the positive and negative connections.
    • For more information on soldering and desoldering connections, please read the How to Solder and Desolder Connections Guide.
  6. Oontz Angle 3 ULTRA  Battery Replacement: stap 6, afbeelding 1 van 1
    • After you have disconnected the battery from the motherboard, use a box cutter or exacto knife to carefully cut the blue wrapping around the battery.
    • Aligning the edge of the knife tangent to the battery works best for avoiding a cut to the electrolyte itself.
    • Please take extreme caution with this step. You may remove the blue tape with another method but if you do use an exacto knife, please do not cut into the battery.
  7. Oontz Angle 3 ULTRA  Battery Replacement: stap 7, afbeelding 1 van 1
    • Once cut, it should require no more than your fingers to peel away the blue wrapping around the battery, and expose the terminal.
  8. Oontz Angle 3 ULTRA  Battery Replacement: stap 8, afbeelding 1 van 1
    • Finally, use the soldering Iron on the two terminals of the battery connection to disconnect it from the wire.
    • To reconnect the battery, solder the two terminal connections, or use the replacement battery's wires to reattach to the motherboard
Conclusie
Één andere persoon heeft deze handleiding voltooid.
2 opmerkingen
Could you please provide a source / part # for the replacement battery?
Is it just two 18650 style 3.7 Volt lithium batteries in series or parallel?
Alex - Antwoord
Was able to narrow down the issue to the board using a known good 18650 battery. Also have seen a couple forum posts saying it’s the board that goes bad on some of these units. Now I’m starting to wonder if it’s just a bad capacitor or something replaceable with a standard soldering iron…
Alex -
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 40
Altijd: 2,716
